no its the source level adjustment on my pioneer deck. I had it at 3 during the comp. today i set it to 4 then re tuned with my dd-1 and my max volume decreased to 33 out of 40 instead of it being 34 out of 40. just curious about this.
ok,first of,the class you're in,is hard.guy's hit over 150db's in that class.addictive audio,i think is one of your problem's.they're not compition sub's.if you're box is built right,i would change up those sub's.you can be louder,but it'll cost you.i couldn't make that show,but i'll try to make the fresno and maybe san jose one.i would be more than glad to help you out if i can,if you decide to continue this,and make more show's.
yea i do want to continue to compete and i would appreciate the help. ha I liked my addictive audio subs lol, it was recommended to me by a shop who i trust. But im open to new ideas, what subs do you compete with?
There's a lot of tricks to get louder... I assume you were at corcoran show... were did you put mike? Driver seat passenger door open works best for me.. upgrade the 925 to a bigger batt.... 3100 would be best..what's your voltage drop to now?...ill help you out at shows...I've seen addictive get loud so stick with that for now... I'm curious on what your box looks like and who built it...
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
Yea it was in Corcoran. They put the mike on the passenger side and I was loudest with my door open. My box was made my by auto sounds of Bakersfield, from what I recall the box was designed by Brian from addictive audio.
I have 2 15's in my truck,no wall,or cut-through,same amp,and I do 149 db's on music.A lot has to do with your box.But just from experience,some sub's don't get as loud as other's for the same price range.
i find this contradictory, considering the subs he is running are essentially identical to your hdc's.
OP, stick with the addictives. Im not an addictive fan, but they can get loud and will handle your amp all day without breaking a sweat. Im almost certain you can burp on 60a, and techically you would be allowed up to 75a in m2. For your first time out, thats a respectable # at a low frequency
Team Flex Issues
Low tuning > God
2011 CALI AS1 STATE CHAMP
  • Who's Online   0 Members, 0 Anonymous, 657 Guests (See full list)
