C1500 build. DC 9.0K, dual singer 350a, air suspension and Fi audio
Idle is normal. The fans is whats killing you
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
i will try and check voltage at the battery with everything on.. i think the stock alt should be able to handle the amp draw.. i have done the big 3 with 4 gauge and the amps and sub are out but i still see the draw.. even if i rev it to 2k rpm it wont climb back up to 14 or 13 volts
i like it too but i think i will not use it after all.. with that deck i have i need a good processor so i think im going with the 3sixty.3.. its hard to tune it with the eq
um, before you drop big equipment in please upgrade the alt and add some batts.
Maybe run new power wires to the HU and the Epic 160 straight to and from upgraded batt? I would trust the DMM right on the batt before the HU and Epic 160, however if the HU is shutting off at 9 volts than it is clearly seeing 9 volts. Maybe ground everything separate behind the HU with new grounds? ( I did on mine)
so overall your vehicle doesn't drop voltage too bad, just your HU and EQ?
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
yes just head unit and eq only.. i will be upgrading to a 350a alt singer or mechman.. whoever gives me the best deal i guess.. no audio is going in till the alt is in and i have at least 5 group 31 bat bank
350a singer.. just wanted to give him a try.. the alt looks beast and im sure its going to perform.. one thing that is iffi on this alt is that the power bolt is not as big as the mechman.. mechman has a beast bolt where your power wire goes coonnected to . but still seems to have good quality
Singer, fuck yeah! I'm going with him on my volvo when I get the funds together lol. How is the drop overall now? Back when my truck had the e-fans, they MURDERED my voltage, and caused the truck to overheat....
Ditched them and went with a mechanical fan and shroud. Wouldn't be hard for you to get that setup, basically any 3/4 ton 454 GMT400 setup will work. Also never noticed the 95+ dash in this truck...how did that swap go?
  • Who's Online   0 Members, 0 Anonymous, 885 Guests (See full list)
