xmax questions
I am looking at buying a FI sub tomorrow and am looking between fibl or fiq. i see the Xmax of the fiq is more than the BL so that means the Q has more travel space and should be able to push more air and thus be louder and more oriented to SPL applications. this goes against what the website states and what others on forums have stated. where am i going wrong in my conclusions?
thanks.
nothing, gutted
False. The Q is not designed as a spl speaker. They will get loud but from what I've seen a bl will be louder in the same setup. The Q sounds great though and kills the lows.
2013 F150 Crew Cab
Old Build Log
Feedback
2013 F150
As stated, Xmax is not the only factor related to loudness.
What enclosure do you plan to use, and how much power? What type of music do you listen to the most? Do you want really strong low frequency response, or just SPL regardless of the frequency it occurs?
Both subs are awesome, but they were designed for different goals.
Edited by bkolfo4
Current system:
Previous systems:
Maybe you should rephrase the "i want more frequency than a kicker L7 12" part.
i want more frequency than a kicker L7 12 and louder as well. i think the BL covers that. i was just confused by the large xmax on the Q series
no shit, that makes no sense whatsoever.....
So what you're saying is that you want a sub with a broader frequency response curve, that also has more output SPL wise yes? L7s are garbage, they sound like shit in everything I've heard, i only know of one setup that was tolerable, and i actually designed the box for the shop that did the install for the guy. Either the Q OR the BL will both sound better and be louder than your L7, if you build the box right.....Currently I'm debating between Q and BL myself, then I'm debating between keeping trunk and going with a single 12, or saying fuck the trunk, i havent needed it in the past 3 years now, always have had 2 12s back there, and go with a single 15
woman..cant live with em...cant shoot em...guess were all fucked
You might be a Redneck if you use your leftover gutters for a speaker box port...
YOU JUST LOST THE GAMER.I.P. Blazer=========================Last setup was in the 141s on music (37hz) with 2 12s and 1kw in a 4dr blazer.2010 Mitsubishi Lancer DE2 12in Clarions (kept from blazer)HiFonics BRZ1700.1d (at 2 ohms BLOWN) [JBL GTS180X for subs currently 60wRMS x2ch!!!!!! This works for till i get the blown amp fixed] Alpine 4ch salvaged from blazer (currently near death)9887 peerless 7s in the doors and CDT tweeters ran active no speakers in the rearKintik HC1400 under the hood.metered once a while ago, dont remember it...was piss poor compared to the blazer, mid 130s i think....looking to replace subs and amp when i have money.
  • Who's Online   0 Members, 0 Anonymous, 1428 Guests (See full list)
