This box is for DC Audio XL 15 inch.
Here are the specs:
http://www.dcsoundlab.com/xl.html
This is my first box design so if go any thing to say about it i will be glad to hear what you think about it
dont mind the funny number its because i designed it on cm and converted it to inch for the program.
Edited by As-21
Hertz HSK 165XL
Celestra FA475xDC Audio 3.5KDC Audio level 5 12 inchXS Power 6500 on the front.XS Power 3100 on the back.Knukonceptz 0 gauge an 10 gauge OFC wire.
Could do without the 45's innside, but looks pretty good. Also might want to consider a second baffle.
Added second baffle on front and reduced the port length because it add 1 inch to his length so i cut it down by 1 inch so it will be still 30 inch long.
Here the pictures with it:
Hertz HSK 165XL
When you add baffle to front still keep the port and side going to front panel (like first drawing) and baffle goes in-between
Also get rid of the 1x 45 in front right
And 3 pieces of 1" or 1.25" round to brace port wall to front, back wall to front and roof to floor
Edit
Another thing I like to do is 45 the inside of port then radius the leadin and out the make the 45 on outside wall bigger so as the port maintains the same size all the way through the bend
Edited by john253a
If i understand your notes on the box here is a picture with the corrections.
about the 45 in the port i think the best and accurate thing to do to maintain the same port width is to round
both of the corners like i did, i don't know if its practical on real life.
Hertz HSK 165XL
Ive done that now still there is some tiny areas the aren't in the same width the only geometric shape that can do that is a circle so the radius will be the same like i did
before.
Also Ive added this time bracing for the walls like you suggested.
Edited by As-21
Hertz HSK 165XL
  • Who's Online   1 Member, 0 Anonymous, 564 Guests (See full list)
