Finally started my build!!!
I am starting out by putting two Power Acoustik Mofo 154X subs in my charger. I'll Be hooking them up to a BAMF 5500.1D amp. I'll tryto post pics as i go but i don't have many yet. (btw i know that power acoustik is crap but i'm 17 and a little limited on $$)
got my power and ground done
it's to easy to run wires in my trunk...
didn't take any pics while i was building my box... here's a quick test fit before i put on the outer baffle which will also serve as a foot/stand and hold it parrallel
attaching the outer baffle
didn't have the money for the integration kit and a new headunit so I decided to go with an LOC... got a good one from my boss for pretty cheap. here it is along with my amp turn on wire and switch
just another pic of the switch
I'll try to get more pics as i continue my build and update as i get them.
Edited by nw1234567
last 3 pics are all exactly the same >_>
Nevermind: Fixed...
Edited by TylerParrish
What the f**k is an appropriate signature supposed to look like?
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
Rockford Prime 200.2
Pioneer 6.75" Comp Set
XS S3400, D2700
Project DB Battery Terminals
Axxess ASWC
Stinger HPM Everywhereeee
90 Sq. Ft. of Stinger Roadkill
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/
My Old Build: http://www.stevemead..._+2000 +mustang
Avatar Courtesy of SnowDrifter
so thats what a stock trunk looks like. LolL ;)
looking forward to seeing more pics, seems like everyones building a charger up right now.. AudioTistics just did, I currently am, now you! good luck :D
Edited by Audiofanaticz
Finally adding some more pics. Got the subs in and playing and they slam pretty hard:). Just have some asthetic stuff left to do and then my bass will be done!
Finishing off the box:
Measuring up the holes
holes measured up
cutting the holes out the old fashioned way
1st hole cut
both cut
laying up the vinyl for the front of the box
vynil glued on and cut to size
Running some wires:
the old zip tie trick
Finding an ignition fuse to hook up a fuse adapter to for the remote wire
LOC all wired up (its just stuck up there temporarilly at this point
Remote wire hooked up and ran
wiring subs into box:
crammin the "recommended" 8awg wire into one of the subs
the ultimate way to mark the neg speaker wire
one sub in and wired
both subs wired up in parallel down to 1 ohm... speaker wire run out of box and siliconed up
finishing putting subs in the box:
screwing them in...
spray painted the back of the box just so no wood shows when i put the amp on and make a face plate
Made a cut in the trunk carpet so i can fold it up and still access the batt and spare with the box in
Time for some sound dampenning mat:
I did the side pannels of the trunk and the trunk lid too but forgot to get pics...
And finally...
I'll post a vid at some point (if anybody wants to see a specific song just leave it in the comments) and i'll post more pics after i make face pannels etc.
I use a glue/paint sprayer hooked up to an air compressor with some contact adhesive. just made some overlay on the vinyl and sprayed both sides then carfully pressed down the vinyl.
Oh, and don't sweat the subs or anything.
We care about the pride you take in your work, not the brands you use :)
  • Who's Online   0 Members, 0 Anonymous, 1160 Guests (See full list)
