Voltage drops to only 13.8.... Should be way more
it could be a myriad of items. one coil out of phase iwll kill your output.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
the problem is that theyre wired to 2 ohm, theyre not getting enough power to even start going. sucks
Might have to sell them... =/
Please correct me if I'm wrong, but with the constant power amps from RF the 2ohm and 1 ohm output should be very close?
97 Suburban
8 custom PSI Platform 3 18's
your right power should be very close.
XS Power D5100, 2 D2700s, & 2 D975s
MechMan 220a Alt
DC 5K
Kicker 650.4
2 12 Ascendant Audio Mayhem's
Pioneer DEH-P7200HD
Rockford Fosgate 3sity.1
Build log: https://www.stevemeadedesigns.com/board/topic/166792-88-nissan-maxima-trunk-build/#entry2430899
https://www.stevemeadedesigns.com/board/topic/191439-lexus-is300-fi-crescendo-shca-rf-pics/
checked wiring with a DMM theyre both at 2 ohms
Amp should be giving a 2 ohm load... dont know why these things arent beating at all.
Going to wire it down to .5 ohm tomorrow and possibly use 2 rockfords to see if it fixes the issue.
Wait they're BOTH at 2ohms??
Build log: Click
Feedback: http://www.stevemead...xbccp-feedback/
03 Chevy Blazer
- IPad Air 2
- ALPINE Head Unit
- 4 DC XL 18s
- 2 DC 3.5k
- ALPINE TYPE R 5.25 COMP
- 3 ALPINE TYPE R 6.5 COMPs
- DC 175.4
- DC HO Alt
- D3400
- 4 XP3000s
- KNU 0ga
- 60 SqFt Damp Pro
Lots more...
If they are both wired to 2 ohms and each sub connected to their own speaker outs on the amp (which is internally bridged) then the amp should be seeing 1 ohm
I've gotten a blowjob and picked up my iphone behind her back to see what email notification I got from smd before
so wait...they're at 2 ohms while hooked up?
before you go and wire to a dangerous ohm load on an amp that is veeeeery expensive to fix, unhook all speaker wires from all subs so you just have the terminals. measure each voice coils' impedance. report back
Can you take pics or draw a diagram of how its wired? I think that would help us understand what's going on
Build log: Click
03 Chevy Blazer
- IPad Air 2
- ALPINE Head Unit
- 4 DC XL 18s
- 2 DC 3.5k
- DC 175.4
- DC HO Alt
- D3400
- 4 XP3000s
- KNU 0ga
- 60 SqFt Damp Pro
Lots more...
i did, resistance at coils is 2.7, then each is 5.4-5.6 after series, normal
each sub is wired in series, then in parallel at the amp,
the final load is 2 ohms, 100% sure.
i assume the subs just arent getting enough power.
this thing isnt even doing a 140 according to my ear-o-meter. maybe a 135
bad bad bad
  • Who's Online   1 Member, 0 Anonymous, 1815 Guests (See full list)
