Hey everyone, so the stock alternator in my 1998 4runner 3.4L V6 is not doing it for my system. I think it only runs like 70 amps max.. My lights dim a lot when i turn my subs up and my amp sometimes cuts off and starts blinking a yellow light on heavy mid notes then turns back on when notes return to lows and highs. From what I read that means I'm running low on voltage and need a new alt. Therefore, I'm looking for advice as to what high output alternator i should go for, I will list my current system specs and if anyone could point me in the direction of a good H.O. alt for my car & system that would be awesome! My budget is anywhere up to $800.
My system currently consists of:
Head unit:
-Alpine IDA-X305
Sub Woofer:
-Kicker zx2500.1 with 1/0 gauge wiring from batt. & ground running at 2 ohms
-25 farad capasitor
-2 kicker L7 15's
-4.7 cu ft custom box tuned at 25 hrtz
Speakers:
-Alpine PDX-F4 with 8 gauge wiring from batt & ground
-Alpine Type R spr-17c & spr-17s speakers
Battery:
-Toyota True 2 (0554-035T2-525)
I will be installing the Big 3 upgrade along with my new H.O. Alternator.
Well honestly get the biggest one you can afford, and for $800 thats easily do-able to get one that meets your needs
Look at mechman, DC power, Singer alternators
13 Kia Forte Build!
07 Hyundai Accent Build
***Super Seller***
N8ball2013
Yeah basically what he said, all the top alternators are within your budget, its up to you to chose. Trey named the best ones
google excessive amperage, they run out of florida. very good pricing.
SUBSCRIBE AT YOUTUBE! 18abVFL < CLICK!!
2005 Subaru Impreza
My build log.
Head unit- Kenwood Excelon KDC-X695
Front doors- Rockford Fosgate 6.5" Prime components
Rear doors- Rockford Fosgate 4" Punch coaxials
Sub amp- Audiopipe AP18001d
Subs- Two American Bass TNT 10"s
Box- 2.6 cubes @ 34hz, 36in of port
Big 3 & run of Raptor 1/0 to rear powercell
TEAM 808 UPSTATE NY.
Can it be heard 2 blocks away, thats how i rate systems.
biggest one you can get from mechman or dc power or something similar to them.
why do you want to tune your box to 25hz?
Looks like I got a 220a for that truck for 5 beans.
And yes, the largest you can get but it also depends on your batteries. The alt and batts work together.
The more power you want, the more batts you need, the more batts you have, the larger the alt that you need.
Ed Lester
ShowtimeSPL Host
Showtime Electronics Video Marketing
My old Build Log
http://www.stevemead...08/#entry511451
http://www.youtube.com/showtimespl
5 time dB Drag Finalist
Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music
New Ride, 2008 HHR SS. Build under way.
Loudest score ever = 171dB
2009 dB Drag Racing, North American Points Champion
What you should do, is run a nice AGM batt up front like an XS D1200 and a small supplemental in the back like a XP750.
That will be good for 3500w systems. Or you can go to a XP950 or larger or add more later. But that setup, with the 220a alternator would run very nice with 0awg wire all around. And can be had for your budget of $800
Ed Lester
ShowtimeSPL Host
My old Build Log
Posted (edited)
So i ordered a 270 amp alt from DC power, so I've got plenty of room for power. Now how many batteries and what type do i need for that alternator? Also, is it necessary to add more batts if i'm only going to be running this system while the car is on?? [quote
name=Kranny' timestamp='1341596021' post='2081668]
And to Kranny, the box was made by a friend according to kickers recommended spec's for these subs or something. I'm planning on building a new box tuned to 32 hrtz. Any recommendations as to how big i should build the box for the amount of watts I'm putting to the subs and the tuning? I was thinking about 8 cubic feet with 125 sq in. of port area. And that's inner chamber cubic footage including all port and sub displacement.
Edited by jabo6692
  • Who's Online   0 Members, 0 Anonymous, 577 Guests (See full list)
