Why are Amplifiers So Expensive?
JWBryant
True, a resistor doesn't cost much, but a resistor with a very small variation will cost loads more. An end product using the same design will certainly do the job with both ranges, but there will be some variation in power, sound, durability, ...
Sony had good amplifiers: the ES range...
Woofer: 12" Phase Linear Aliante Limited
Mids & highs: DLS Ultimate 5 1/4"
Amp: Audison VRX 6.420
HU: Sony CDX-C90R
For us oldschool guys I remember paying $3dollars a watt.... I say some amps are a lil beter an cost more look at phoenix gold they use gold on there trace etc...and I know dc 12ks have new super fets that are expensive plus the driverboards etc
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
It's not just the name like stated before, And it's not just a simple component swap like stated before.
One factor is production numbers as stated before. It will cost much more per amp to produce 20 amps than it will to produce 2,000.
But also, thats only comparing similar amps.
For a huge price jump, like going from a $400 amp to a $1000+ amp of the same power range, you have an entirely different design with an entirely different set of components, standards, production numbers, and quality.
Take Helix or Audison for example, Their components are not simply beefier versions of what is in cheaper amps, they actually use different types of components, all within a 1% tolerance whereas cheap amps can have a 10-20% tolerance.
And instead of basic PCB and standard jumpers, they take the time to engineer the board layout and connections for the least amount of loss possible.
They use pure copper and gold plating in their connections.
They also utilize control devices to perfectly match and filter input signal. These amps have a great damping factor (ability to control speaker) And a very high signal to noise ratio that you cannot find in cheaper amps.
What you pay for is not the name, or higher quality components, what you pay for is the engineering time and attention to detail in production and QC that went into each amp. To ensure its quality and reliability as well as its ability to achieve the purest sound possible.
Now non of that matters if you just wanna go "Wang" on some woofers and make them "Hit"
Ed Lester
ShowtimeSPL Host
Showtime Electronics Video Marketing
My old Build Log
http://www.stevemead...08/#entry511451
http://www.youtube.com/showtimespl
5 time dB Drag Finalist
Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music
New Ride, 2008 HHR SS. Build under way.
Loudest score ever = 171dB
2009 dB Drag Racing, North American Points Champion
Lmao. I <3 Ed
hiiiiiiii
2002 4runner - buncha speakers n amps n shit (gone)
1994 astro - more stuffz
update: pretty sure all the pic links in the logs are broken lol.
ma slop garb build log
16 12's 4th order
4runner rebuild in progress
clickkk meeeee!!!! 4 18's 6th order
UBL - clicky
http://www.youtube.com/yyj11589
lots of hater kids here. Pay no attention, they just want 89,000 watt subs for 3.50
If you would have put a dc dustcap on it and called it lv your mom, they would all be in love
phhhh...if you think Car Amplifiers are expensive, you should look at Home audio Amplifiers, some of them cost more than cars.
But in general, they are pricey cause of good parts, and build quality.
2003 Kia Sorento
Team Subsonic Lows
Team Bassin' on a Budget
As i view it, when you pay high price for a new product, you also have to pay for the research required in making that product, and as the technology gets older, price goes down.
So i'd say, high price for some amps (rf amps for example) could be due to the new technology in them.
1997 Ford Ranger
2 - Rockford Fosgate P3 600w 12s
1 - Soundstream Rubicon 1.1000d
Pioneer Mids/highs
Blacked out tail lights (removable, done with 20% static cling tint)
Nicely said Ed! That last tag under your name seems correct :good:
That's why some brands even have different product lines producing same output figures at quite some differring prices.
HU: Sony CDX-C90R
Also, larger companies like Pioneer can afford to produce things in mass quantity and for cheaper, thus them being able to sell product for cheaper. Smaller companies have to charge more because it costs them more to manufacture.
Alpine CDE-164BT/Rockford Fosgate P400X4
Kicker CS 6.5" Components (Front)
Kicker 6.5" Composites (Rear) (Running at -10DB for soundstage)
RF P400X1 Monoblock
2x Rockford Punch P1 12" 4 OHM SVC running @ 2 OHM in sealed 1" MDF box.
I giggled a little
  • Who's Online   0 Members, 0 Anonymous, 1181 Guests (See full list)
