Mr. Yuk's rebuild. 2 DC XLm2 18s AB500.1 SUB SONIC ADDICTION!!!!
  • 1 month later...
really no replies to this build? i feel like im wasting time posting it on here
nice clean setup what do you have as far as electrical?? i have a tahoe with 2 18 smds myself and got a triple alt setup. best money i spent yet on a system yet i can full tilt with about only .1 or .2 voltage drop.
Where is the amp mounted? Box looks good! Any pics of batts/wiring so we can see what's goin on?
I have an 06 Tahoe with decent electrical if you want to check it out on here.
Keep up the good work.
06 Police TahoeHU- Pioneer 80prsAmp- Crossfire 8kSub- 4 15" Crossfire xs v2sWire- 1/0 Knu/AudiotechnixAlt- 3 Mechman SMD 340sBatts- 6 XS Power 3100s, 2400
I have 3 group 31 batts and a d3400 under the hood im waiting on an spx 300 amp alt from dcpower and the amp is temporarily mounted to the back of the seat. I have yet to get numbers but my amp seems to be working quite a bit more now that the other half of the board is fixed im guessing right about a 150 its a lot louder.
What year Tahoe? Ever consider mounting the amp under the backseat? I'd imagine it'd be less prone to vibration under there.
nice build, cant wait to see the new numbers. how far away from the back of the truck is the port? gotta make sure it has room to breath, ever think about moving the box closer or further away just to see what it can do?
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
  • 2 months later...
alright another update! still running the same ab500.1 andthe same box with some upgrades.. major changes would be im now running a dual alt setup with 3 new group 31 batts in the rear and d3400 in the front. after installing the dual alts i metered a 148.1 and after a day or two of trying to figure out what was going on i found out i blew my 150 amp fuses separating front and back battery banks. so on 10 volts i did the 148 we hooked it up and metered it about 20 minutes later and did a 150.4 on about 11.9 volts lol im gonna let these batts charge a bit and do some more testing. also broke my port in the middle so i need to add some more bracing to that as well.
