You need to fuse the positive wire goin to the amp. And it need to be fused according to the wire's rated capacity. Also you need I put the fuse close to the battery so you have the least amount of un-fused wire as possible.
The whole point of fusing is to protect the wire from being overloaded incase of a short. The amp should have its own onboard fuses to protect its circuits
100 amp fuse on the positive wire, as close to the battery as possible should do the trick.
I like to quatoe Steve Meade again and again and again "Use fuses, incase of carbeque" out of the Rockford Fosgate Magazin.
"in the abundance of water, the fool is thirsty" Bob Marley
fuse for under your hood or between a dist block and amp? I have a 150A inline fuse in my dist block for the line that goes to my BRZ (since the BRZ doesnt have its own fuse it seems) Under the hood, for my main run, 300A i think.
yeah fuse the line going from the positive battery to the amp.
have the fuse as close to the battery as possibly(like 6" away)
and for a 1200watt amp i would suggest a 120amp fuse.
  • Who's Online   0 Members, 0 Anonymous, 2252 Guests (See full list)
