soundstream15 Posted July 15, 2012 Report Share Posted July 15, 2012 i have sony 6x9s in my rear deck, i got a alpine head unit and its alot louder then my kenwood, sounds like a have a 4channel amp hooked up to my mid and highs, i got everything tested with the dd-1 and and my head unit is not clipping but when i turn it full tilt, volume 30/35 sub level at 11. it sounds like my mids are distorting..idk if it is because there sony speakers..hopefully someone can help me..ill buy new ones if i need to once again head unit was set with a dd-1 Quote Link to comment Share on other sites More sharing options...
LZTYBRN Posted July 15, 2012 Report Share Posted July 15, 2012 (edited) Do you have a high pass on the mids? My guess is the low frequencies are what's making them sound distorted... Not sure but you should be able to put a filter on them through your head unit. Edited July 15, 2012 by LZTYBRN Quote Link to comment Share on other sites More sharing options...
MrSkippyJ Posted July 15, 2012 Report Share Posted July 15, 2012 sub level at 11? I am assuming you have subs in the trunk. That could be it... Quote F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69 Link to comment Share on other sites More sharing options...
SnowDrifter Posted July 15, 2012 Report Share Posted July 15, 2012 How did you set it with the dd-1? Via the RCAs or the speaker outputs? Usually, the internal amp on the headunit will clip sooner than the preouts, so even though your preouts may be clean - your speaker outputs on your headunit can be clipping badly Quote ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444 Link to comment Share on other sites More sharing options...
C-Fizzy Posted July 15, 2012 Report Share Posted July 15, 2012 (edited) Just because you set your HU with a dd-1 doesn't mean your speakers aren't shit lol Edited July 15, 2012 by C-Fizzy Quote under construction I hate People with crappy primered cars rolling on hubcaps that are louder then me. u hate c-fizzy? Link to comment Share on other sites More sharing options...
soundstream15 Posted July 15, 2012 Author Report Share Posted July 15, 2012 yea i have a hpf, its set at 80hz on the head unit..i do have subs in the trunk but even with the subs off and the volume up it sounds like its distorting, im not trying to sound dumb or anything...and using the dd-1 it was tested thru the rca's...i understand the internal amp will clip before the preouts but does that mean im clipping the head unit? idk if anyone uses sony speakers on here.. please no smart ass comments, im just trying to learn Quote Link to comment Share on other sites More sharing options...
Sean Sinha Posted July 15, 2012 Report Share Posted July 15, 2012 yea i have a hpf, its set at 80hz on the head unit..i do have subs in the trunk but even with the subs off and the volume up it sounds like its distorting, im not trying to sound dumb or anything...and using the dd-1 it was tested thru the rca's...i understand the internal amp will clip before the preouts but does that mean im clipping the head unit? idk if anyone uses sony speakers on here.. please no smart ass comments, im just trying to learn Believe it or not, those Sony's might be struggling with 80Hz, try 120HZ. Quote Alpine CDE-164BT/Rockford Fosgate P400X4 Kicker CS 6.5" Components (Front) Kicker 6.5" Composites (Rear) (Running at -10DB for soundstage) RF P400X1 Monoblock 2x Rockford Punch P1 12" 4 OHM SVC running @ 2 OHM in sealed 1" MDF box. Link to comment Share on other sites More sharing options...
Sean Sinha Posted July 15, 2012 Report Share Posted July 15, 2012 yea i have a hpf, its set at 80hz on the head unit..i do have subs in the trunk but even with the subs off and the volume up it sounds like its distorting, im not trying to sound dumb or anything...and using the dd-1 it was tested thru the rca's...i understand the internal amp will clip before the preouts but does that mean im clipping the head unit? idk if anyone uses sony speakers on here.. please no smart ass comments, im just trying to learn Set your HPF to 120 and your LPF to 80. See if that clears up the mids at all. Quote Alpine CDE-164BT/Rockford Fosgate P400X4 Kicker CS 6.5" Components (Front) Kicker 6.5" Composites (Rear) (Running at -10DB for soundstage) RF P400X1 Monoblock 2x Rockford Punch P1 12" 4 OHM SVC running @ 2 OHM in sealed 1" MDF box. Link to comment Share on other sites More sharing options...
soundstream15 Posted July 15, 2012 Author Report Share Posted July 15, 2012 really? i have my low pass filter on my amp at 80hz but does that mean i gotta set my it on my head unit at 80hz? i will try 120hz man Quote Link to comment Share on other sites More sharing options...
Sean Sinha Posted July 15, 2012 Report Share Posted July 15, 2012 really? i have my low pass filter on my amp at 80hz but does that mean i gotta set my it on my head unit at 80hz? i will try 120hz man You said your HPF was set to 80. If you have your HPF set to 80 and your LPF on an amp set to 80, that's not right. Set your HPF to 120 and your LPF to 80. Quote Alpine CDE-164BT/Rockford Fosgate P400X4 Kicker CS 6.5" Components (Front) Kicker 6.5" Composites (Rear) (Running at -10DB for soundstage) RF P400X1 Monoblock 2x Rockford Punch P1 12" 4 OHM SVC running @ 2 OHM in sealed 1" MDF box. Link to comment Share on other sites More sharing options...
