DC Sound Lab
Too much power for lvl 6??
Missed that cj. I honestly think its a bit large for that much power it is still a four inch coil right? Throwing retarded amounts of power at a single woofer is never a good idea. If it was out of phase it would heat up but output should be reduced as well you'd think that would be noticeable in a single sub setup,
I dont think it is way too big, but I would be at 5-5.5 net.
Also he could be running into serious voltage drop and that could be causing issues as well. A 5k at .5 is a silly amount of draw
now that i think of it this sounds reasonable i see 3 xs3100 but no h/o alt and your running a dc 5K at .5 ohm
skar sk2500.1
alpine HU
vxi65 components on BA gt-275
2 x-15 sundowns
I would check what ray said. If the coil is wired out of phase that could cause this issue.
how would i check if it was out of phase i guess lol dont wanna do it wrong and do something i kno the phase setting on the amp is at 0. Sub level is 15/15 and i only drop .4 from 13.6 full tilt i got 5 xs d3100 lol
89 Ford Bronco 2
6 DC XL M2 12's
1 DC 9K
Dual Singer Alts
7 Xs D3100s & 1 D6500
All Audio Techinx OFC 1/0
Doing 55s at 26hz!!!
Isn't this the same user who burned the last level 6?
lol yea but ive learned from that and never had a problem till i switched decks
89 Ford Bronco 2
6 DC XL M2 12's
1 DC 9K
Dual Singer Alts
You said you used the DD1 on your amp, but when you checked you Headunit, was the sub level at 15/15? I always leave my sub level at 0 and then set my gain accordingly. This would be my first recommendation for adjustment.
dc5k @ .5 on stock alt?
The poor alt :o
i shook this one kids hand and it just folded in mine. long story short i fucked his girlfriendso.. yeah..
You want this to happen to you? Give decent handshakes people.
I was gifted with an innate ability to distribute wholesale ass beatings in a timely and orderly fashion.
if u set the sub at 0 the dd-1 wouldnt pick up the signal ive done it b4 and thought the dd-1 was broke and the sub level was at 0
89 Ford Bronco 2
6 DC XL M2 12's
1 DC 9K
Dual Singer Alts
  • Who's Online   2 Members, 0 Anonymous, 1260 Guests (See full list)
