DC Sound Lab
I see dual leads on it also, it might have a Lv5m1 coil option in it but its a older sub with no venting in the frame so you cant see the coil to say for sure.
DC AUDIO
Phone Number
1(855)SPL-DBZZ
Built by Competitors, for Competitors.
I have some beat up sony subs laying around, single 4. I just when and ohm them and they read 4.8? Thats not a full 1.5 off
The impedence of a woofer is more of a ballpark, if you look at the sony's t/s it is probably 3.5ish DC resistance.
Ok, well good deal then. thanks for posting up that little heads up. I about just scrapped a level 4! Im going to upgrade multi meters just to be a bit safer. In all my years of ohms I have never thought of this. You guys are amazing, thanks!
I know when I got it the negative lead of one of the coils was burnt right at the cone so I removed the dustcap and re soldered the wire. Anything I could of seen while I was in there to confirm this?
Could you see if it was a flat wire or round wire coil? flat would be the XL upgrade and round would be a stock LEvel 4.
the lead from the coil was round wire. I could not see the vc, there was a metal sleave over it. Im going to say its a regular level 4
