Level 4 18 coil smell?
maybe it is just smelling because it is in the brake in period. don't play it full tilt if it is not broke in yeat. Here a little video to show why it is important to let them brake in.
Edited by TrentonLong
you are not even remotely following the manual for the dd-1
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
imma try the wire upgrade ( was doing that anyways, tune to -5db (still a 4 or so db jump. and ill tune with sub hooked up. and the song i can notice it one is play my game by gucci which i got from a decaf zip also the song play my game by dorrough, same zip. . . those are just some i noticed the smell
read the manual again.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
track 1 to find head unit white is a Kenwood KDC352u (i belive) thats 40hz at 0db (just to confirm) deck doesnt clip on EQ all at 0. so then i turn bass to -8 mid to -4 and treble is at 0.
i go to my amps, turn my gain knob (not bass boost) to half and use track 5 40hz at -10db i believe. . . and usually i back it down a hair, so its more than -5db but not quite -10. . sub isnt hooked up when i do so and voltage sits around 13.45 when i do it
You did a couple things wrong in those steps you just posted.
Edit- Damn Ninja N8 got to it before me :)
Edit- Also just noticed i hit the 1000th post mark :)
Edited by Real96SS
Vehicle
2007 Chevrolet Avalanche(Co-Co)
DNX9980HD
6 Team Fi 15's(King Edition)
3 DC 9k's
8 Nendo PWX 8's
4 Custom Steg 4" Super Tweeters
1 DC Audio 175.4
1 DC Audio 90.4
Rockford 360.3
3 DC Power 370xp Alts(Externally regulated)
21 D1600's
2 D4800's
All SMD RCA's
AudioTechnix Deadner
Viper Alarm
My YouTube- http://www.youtube.c...NG?feature=mhee
Link to buildlog- http://www.stevemead...4-15s-2-dc-9ks/
Link to UBL- http://www.stevemeadedesigns.com/board/topic/165059-ublkings-avalanchecoco-new-build-starting8-king-edition-15-team-fis-in-a-wallyes-a-wall/
the only thing i see is to keep the eq flat until after i set the amp gains. . . ive done it both ways and haven't noticed a difference in gain on the amp. . everything else i did seems to be correct
after work im going to switch my wire. and DD1 it all again but i mean ive done it like 50 times to see if i did it wrong so :/
Edited by Mikey Bates
everything flat. That measns bass and treble at '0', not -8 and -4. Leave your gain all the way down. Play the tone you want, and slowly increase the gain until the clip light comes on. Then back it down a notch.
Are you using a remote bass knob?
Are your speakers hooked up when you are setting the amp? Should not have subs hooked up.
Is your car off? Should be off.
SMD Super Seller
My Feedback Thread
I'm not surprised you get coils hot using a -10db tracl.
You're leaving a FUCK TON of head room to send you amp into clipping.
Set your amp with at 0db track and you should see an improvement.
It won't get as loud at the same volume level but at least you know for 100% sure that you can't reach clipping even on a 0db tone.
  • Who's Online   0 Members, 0 Anonymous, 1369 Guests (See full list)
