battery and alt should be in very soon!
2001 GMC Sierra DC Audio Build =http://www.stevemead...o-level-4-build
2001 GMC Sierra
XSPower D3400
Pioneer AVHD 1400
​MB Quart Component Sets
Pioneer 5x4s
Audiotechnix Power Wire, Speaker Wire, Sound Deadener
DC Audio Level 4 10s
DC Audio 3.5k
Rocford Fosgate R400-4
HID 6k
Slammed Truck on 20s
Candy Blue.
should i buy some deadner for my back wall and doors will it make much a difference?
2001 GMC Sierra
XSPower D3400
Pioneer AVHD 1400
Pioneer 5x4s
DC Audio 3.5k
HID 6k
Candy Blue.
I didn't deaden my back wall, just the trim panel underneath that goes the full length of the cab. I fully deadened the doors as well. The only thing I get rattle out of(and I don't think fords have it) are these vents on the back of the cab that are about 2-3 inches wide and 10-12 inches tall. These big skinny vents that I really have no clue what they do. Theres like a one way flap in them and it vibrates a little you can hear outside the truck. From inside though, the B-pillars are about the only thing that make a little noise. Since youre firing your port at your B-pillar like I am, you may think about deadening that sheet metal under the trim.
I would say yes. Back wall and doors. Coming along nicely. Can I ask, not to be picky, but any reason you didn't round off the port edges, and countersink and fill the screw holes?
I had an 03 stepside of these, fit a pair of 12's in sealed enclosure back there, but the center of the enclosure was all funky cause I needed the ability to flip that center piece up. For nothing else other than to hide the box behind it. I had an amp in there so I was able to drop the front back a bit. Miss that truck!
Keep up the work man! Looks good.
Those vents are to vent the air out of the truck when you shut the door. EDIT - Clarification, I'm sure there are other uses for them, but this is what I've been told before. So you don't blow your ears out! On my civic, I put a thin piece of deadener on the ones in the trunk, and it quieted them down considerably! I say thin, I mean thickness thin. Minimal mm if you can get some. Or even just a couple little squares if you can't find any thin stuff. You need those vents to do their job and weighing them down with big thick deadener is not going to do that. Just my $.02
to tell you the truth i dont know why i did not i am kinda mad i did not round the port and stuff and the screws i know i should if i guess i was in a rush to finish. do you think it will make a difference if i round the port edges now? will i have a gain at all?
2001 GMC Sierra
XSPower D3400
Pioneer AVHD 1400
Pioneer 5x4s
DC Audio 3.5k
HID 6k
Candy Blue.
A center console for a buddy of mine. the top is on the table.
2001 GMC Sierra
XSPower D3400
Pioneer AVHD 1400
Pioneer 5x4s
DC Audio 3.5k
HID 6k
Candy Blue.
what screws should i use to mount the subs?
2001 GMC Sierra
XSPower D3400
Pioneer AVHD 1400
Pioneer 5x4s
DC Audio 3.5k
HID 6k
Candy Blue.
I use pan head screws or you can use t-nuts It really shouldn't matter to much unless it a really heavy sub upside down or on its side.
Btw build looks good
"SilveradoGoesBang"
http://www.stevemeadedesigns.com/board/topic/155256-silveradogoesbang-box-done-take-notes-on-bracing/
2 FI BTL 18's
CT Sounds 7k
2013 MidwestSPL Finals Xtreme 3 - 1st Place
Thanks man and the sub is going to be on its side will it affect anything.
2001 GMC Sierra
XSPower D3400
Pioneer AVHD 1400
Pioneer 5x4s
DC Audio 3.5k
HID 6k
Candy Blue.
  • Who's Online   0 Members, 0 Anonymous, 2293 Guests (See full list)
