pssstgotbags94 Posted July 17, 2012 Report Posted July 17, 2012 I recently purchased a planet audio vx2004 from the local pawn shop. It was marked broken for $10, didn't smell burnt and had no fuses. I just assumed whoever bought it and returned it didn't know it needed fuses. I put fuses in it and it powered up. But I get no sound output. I opened it up to find the connections from the bored to the speaker output terminals were broke. Here's a pic I figure I'll just solder leads direct to the board and attach speaker wires direct to them. I know how to solder electronics so I'm not too worried about getting the board too hot or anything. And if I do ruin it, who cares, $10 isn't much lol. Any other ideas before I try that? 2004 Nissan 350z slammed on topspeed coilovers pioneer appradio B2 audio Quota for sub B2 audio HN15 sub Lunar L2200 for highs Infinity kappa 60.9 components in doors Under construction still.
bass_stalker Posted July 17, 2012 Report Posted July 17, 2012 what amp is it? it probobly is fixable but i'm no amp engineer, so i couldnt tell you if just soldering would fix it JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
Swordlordboy1234 Posted July 17, 2012 Report Posted July 17, 2012 Sounds like even if you mess it up... You used 10$ to find out how NOT to repair an amp! GL bro My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37 My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/ 2016 Mazda 6 Touring JL Fix 86 - OEM signal correction B2 prototype DSP 6to8 B2 Ref63 - 3 way active set 2 B2 Class H quattro's 1 B2 Zero.5R @.5 2 B2 HNv3 12 d2 B2 SLIP40 - Lithium in the trunk Northstar Group 35 under the hood 100ft 2/0 welding cable 30ft 4ga welding cable 20ft 8ga welding cable All stinger OFC speaker wire Soundrive custom RCA's Tons of attention to detail.... Can it be perfect?
16K Posted July 18, 2012 Report Posted July 18, 2012 sounds like u got a plan try it and find out if it works !! *** 1991 Turbo Walled Civic 400whp @ 20psi *** - JVC KDS88BT Headunit - 4 15" Fi BTL N2 Fully Loaded Subs - 1 SD16kD Amp - 14.5ft^3 Wall Tuned to 37hz with 202in^2 of port - Mechman 220a HO Alternator - 6 XS Power D3100 Batteries - Copper Buss bars - 2 Runs of 4/0 Welding Cable - Big 3 - Stinger Digital Volt Meter Burp outlaw in the kick: 158.9db Music: 157.5db Sealed on the dash: 157db - SPL Labs Rep for Missouri -
michigancapri92 Posted July 18, 2012 Report Posted July 18, 2012 How do all those break haha Teamcapri.comThe TeamCapri 1992 Mercury Capri XR22012 FORD EDGE SQ BUILDOld build logMy FeedBack1992 Mercury capri XR2 Hyper LED
Guest Posted July 18, 2012 Report Posted July 18, 2012 How do all those break haha cause its a cheap amp
AAKSOKOLD Posted July 18, 2012 Report Posted July 18, 2012 sometimes soldering the wrong way will connect pieces that arent supposed to be connected! Me & My DJ*!
