Hey guys long time no speak, I know the ap30001d is 2 ohm stable, but ive heard they can run @ 1ohm safely with good electrical. Does anybody have any experience or know this to be true....running a dual 2ohm pap wmd2k 18 to it.. thanks again.
https://photos.google.com/photo/AF1QipP7rjav9cD9UFdAYBJmz4M4LoNlF26ng1xhAf4Uhttps://photos.google.com/photo/AF1QipP7rjav9cD9UFdAYBJmz4M4LoNlF26ng1xhAf4U
2013 DODGE CHALLENGER R/T
SUNDOWN ZV4-18
CRESCENDO 3.5K
PIONEER AVIC 5300 NEX
ALPINE TYPE R 6.5S & 6X9'S
ROCKFORD FOSGATE 1.5" TWEETS
5 C&D TECH BATTS
Do you have amp already? If not find a 1ohm stable amp.co worker has wmd218 wih audiopipe to amp at 1ohm amp smoked..got stestom amp way better.those audiopipe amps suck.
im with you..doing a full do-over next season...its what im workin with for now....but i do have strong electrical...i did hear of people doing a mod of some type...
SUNDOWN ZV4-18
CRESCENDO 3.5K
5 C&D TECH BATTS
no. you do realize that the 3000 version is literally just 2 1500 boards stuck in one case?
people who are actually running the 3000 at 1 ohm, have crazy rise, which makes the amp see over 2 ohms.
so, ill run 1 coil to each channel....@2 ohms so 1500 each coil....
SUNDOWN ZV4-18
CRESCENDO 3.5K
5 C&D TECH BATTS
You can run each coil to a channel but its going see 2ohms a channel wich is 750 or you can still bridge it at 4ohms see 1500 its the same. Or you can try bridging it at 1ohm you get more power.
how are they confusing...because they have two sets of speaker terminals?
if you wire each coil to each set of amp terminals, the amp will still parallel them internally. so 2 2 ohm coils will turn into 1 ohm.
  • Who's Online   0 Members, 0 Anonymous, 1008 Guests (See full list)
