HunterJohnson Posted August 17, 2012 Report Posted August 17, 2012 more updates!! I wanna see what this thing can do Scion tC SQ BuildiPad mini, lots of fabrication, daily drivenFord Explorer C Pillar Wall Build Just a cheap car to destroy with bass
412 CVX Posted August 17, 2012 Report Posted August 17, 2012 Before you glue the top on, cut out the port and dry fit the top piece. I want to make sure you can get in and out of the box and mount the woofer. If you can't fit, then let me know and i'll try and design a little mod for you so you can fit. I hope you haven't glued that bracing down yet, because if it needs modified, that might become part of it. Just say no to Ground Pounder Customs. My temp system build log More box buildssome cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches! I'm with captain stupid.
412 CVX Posted August 17, 2012 Report Posted August 17, 2012 Also, you might want to experiment with which end of the box is closer to you. It might be louder with the port closer to the seats, but i'll leave that up to your discretion. Just say no to Ground Pounder Customs. My temp system build log More box buildssome cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches! I'm with captain stupid.
SMZ2 Posted August 17, 2012 Author Report Posted August 17, 2012 Before you glue the top on, cut out the port and dry fit the top piece. I want to make sure you can get in and out of the box and mount the woofer. If you can't fit, then let me know and i'll try and design a little mod for you so you can fit. I hope you haven't glued that bracing down yet, because if it needs modified, that might become part of it. The bracing part isn't glued yet and I think I have to trim the long piece because the width of the inside of the box came out to be a little less than 39... hopefully that won't mess up tuning to much... I'm also going to resin, fiberglass and paint the inside before I put the top on. I was also thinking about putting two led strips in the back port and letting them shine through the pvc to give it a nice bright bluish glow or is this a bad idea? My Build Log!http://www.stevemead...nissan-xterror/ Check the Youtube Channel for Updates!http://www.youtube....ser/Xterror2002And Seller Feedbackhttp://www.stevemeadedesigns.com/board/topic/163179-bought-from-smz2/#entry2363713
SMZ2 Posted August 17, 2012 Author Report Posted August 17, 2012 Here is a can trick with the current box. The box I'm building dwarfs the old box haha. My Build Log!http://www.stevemead...nissan-xterror/ Check the Youtube Channel for Updates!http://www.youtube....ser/Xterror2002And Seller Feedbackhttp://www.stevemeadedesigns.com/board/topic/163179-bought-from-smz2/#entry2363713
412 CVX Posted August 17, 2012 Report Posted August 17, 2012 Before you glue the top on, cut out the port and dry fit the top piece. I want to make sure you can get in and out of the box and mount the woofer. If you can't fit, then let me know and i'll try and design a little mod for you so you can fit. I hope you haven't glued that bracing down yet, because if it needs modified, that might become part of it. The bracing part isn't glued yet and I think I have to trim the long piece because the width of the inside of the box came out to be a little less than 39... hopefully that won't mess up tuning to much... I'm also going to resin, fiberglass and paint the inside before I put the top on. I was also thinking about putting two led strips in the back port and letting them shine through the pvc to give it a nice bright bluish glow or is this a bad idea? wouldn't be a bad idea, although i'm not sure how well you'd see it. Just say no to Ground Pounder Customs. My temp system build log More box buildssome cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches! I'm with captain stupid.
White Lightning Posted August 17, 2012 Report Posted August 17, 2012 Awesome Setup Sir Kenwood / HELIX / Linear Power (For The Love Of Music) / Brutal Sounds / OverKill Electric Co Questions About Sound Quality ?? Try Here ... Sound Quality, What does it REALLY mean ?? SMD SOTM Winner "White Lightning" 1997 GMT400 Chevy Silverado "The Green Dickle" 1994 GMT400 Chevy "Phantom Dually" Randal's 2007 Chevy Avalanche (we haven't named this one yet) Dylan's "Brutal" 17 Chevy Cruze RS Hatch
SMZ2 Posted August 17, 2012 Author Report Posted August 17, 2012 Before you glue the top on, cut out the port and dry fit the top piece. I want to make sure you can get in and out of the box and mount the woofer. If you can't fit, then let me know and i'll try and design a little mod for you so you can fit. I hope you haven't glued that bracing down yet, because if it needs modified, that might become part of it. The bracing part isn't glued yet and I think I have to trim the long piece because the width of the inside of the box came out to be a little less than 39... hopefully that won't mess up tuning to much... I'm also going to resin, fiberglass and paint the inside before I put the top on. I was also thinking about putting two led strips in the back port and letting them shine through the pvc to give it a nice bright bluish glow or is this a bad idea? wouldn't be a bad idea, although i'm not sure how well you'd see it. Yeah I'll test it out before I finalize but if it turns out right this box will stand out forsure! My Build Log!http://www.stevemead...nissan-xterror/ Check the Youtube Channel for Updates!http://www.youtube....ser/Xterror2002And Seller Feedbackhttp://www.stevemeadedesigns.com/board/topic/163179-bought-from-smz2/#entry2363713
SMZ2 Posted August 17, 2012 Author Report Posted August 17, 2012 Awesome Setup Sir Thank you Sir. I love your setup too man I hope to hear it in person someday I've heard it sounds beautiful! Thanks again for the comment! My Build Log!http://www.stevemead...nissan-xterror/ Check the Youtube Channel for Updates!http://www.youtube....ser/Xterror2002And Seller Feedbackhttp://www.stevemeadedesigns.com/board/topic/163179-bought-from-smz2/#entry2363713
