Socky Posted July 19, 2012 Report Posted July 19, 2012 The charger helps a ton, bro ran his batts for awhile and burp a 148.8, and charged the batteries, has never been charged since he got them used, then burped a 150.9. But he has a stock alt, and 4 batteries on a aq2200. Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell Kenwood H/U 1/0 wire, 136 amp alt 200 ah batteries 12.7 daily 2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts Mb quart 125.4 wired to 4 aura 6's 3.6 cube box tuned to 36 plays down to 23hz
Mr.JaunDurfle Posted July 19, 2012 Report Posted July 19, 2012 Putting a charger on your batteries makes for less strain on your alt. If your batteries are charged up your alt doesn't have to work as hard to re-charge them and keep them charged when you are playing your system the next day. 2001 VW Passat Sportwagen Alpine ICS-X7HD DC Audio 5K SSA 15" XCON Tantric Sounds 6.5HD's, Sundound Audio SA-6.5CS Incriminator Audio IA6.4 XS batteries, KnuKonceptz wirez, Second Skin
Socky Posted July 19, 2012 Report Posted July 19, 2012 Just try to maintain the batteries, helps the last longer too, whenever you are driving your vehicle, leave it plugged in, get a reliable charger than trickle charges them, and auto floats. Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell Kenwood H/U 1/0 wire, 136 amp alt 200 ah batteries 12.7 daily 2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts Mb quart 125.4 wired to 4 aura 6's 3.6 cube box tuned to 36 plays down to 23hz
AMI CUSTOMS Posted July 19, 2012 Report Posted July 19, 2012 how does one know exactly what the voltage drop would be? I say it sounds like it should be ample. instal it and leave room or the option to add another batt if you need. It is called experience. Been there done that. Enough said, now carry on. lol To the OP, at .5 ohm you gonna have drop, once you max out the reserve on the battery bank you will start to dip below resting voltage. The alt at that point would be wide open and getting hot as you mentioned. So depending on what batteries you settle on that will determine your reserve. You have to remember that when you wire below 1 ohm you dc amperage intake goes up quite a bit. TEAM SOUNDQUBED -- TEAM SOUTH TEAM S.O.B. - Founder & Captain 3x Streetbeat World Record Holder 2017 MWSPL 1st place Mayhem & 4th Xtreme 4 2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4 2015 MWSPL 2nd place Mayhem & 4th Xtreme 4 2014 USACI 2nd place Streetbeat 5 - 162.6 db 2014 MWSPL 2nd place Xtreme 4 - 144.9 db 2013 USACI 1st place Streetbeat 4 - 161.9 db 2013 USACI 1st place Street Q+ - 162.8 db 2013 MWSPL 3rd Kaos2 & 4th Xtreme 4 2011 USACI 2nd place MOD 1001-2k - 160.0 db 2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db 2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest Best score to date 164.4 db - Termlab Outlaw Streetbeat 4 - 161.9 db Streetbeat 5 - 162.6 db MWSPL on Dash Legal door open (Music) - 162.5 db Sealed on dash Legal (Music) - 161.1 db - Termlab THE BLACK NASTY CURRENT BUILD & FAB The Black Nasty (6) 15 Rebuild Log 2012 (4) 15 Walled Sierra Build Log Evo X build log Facebook page The Black Nasty
Bump4life Posted July 19, 2012 Report Posted July 19, 2012 how does one know exactly what the voltage drop would be? I say it sounds like it should be ample. instal it and leave room or the option to add another batt if you need. It is called experience. Been there done that. Enough said, now carry on. lol To the OP, at .5 ohm you gonna have drop, once you max out the reserve on the battery bank you will start to dip below resting voltage. The alt at that point would be wide open and getting hot as you mentioned. So depending on what batteries you settle on that will determine your reserve. You have to remember that when you wire below 1 ohm you dc amperage intake goes up quite a bit. ill take your word for it lol after i strapped 2 AQ2200s today at .5 ohm. them bisshess dropped my votage like none other. Buyer/Seller Feedback Thread: http://www.stevemead...5015-bump4life/ MB C220 153 Trunk Car Build Log: http://www.stevemead...d/#entry1840136 MB C280 Ipad Dash SQ Build Log: http://www.stevemeadedesigns.com/board/topic/194484-bump4lifes-new-benz-tony-c-relay-kit-pictures-ce-electric-audison-front-stage-installed/ My SPL Log: http://www.stevemead...__fromsearch__1 BMW M340 xDrive Stock, for now. Corner Load 10" maybe soon. But does 10s in the 1/4... Best Scores out of a trunk 153.0 sealed legal full tilt clamped 5524 @ 42 hz 154+ windows down, 155+ kick
gotb00st Posted July 19, 2012 Author Report Posted July 19, 2012 I may consider dropping to 1x 18 fi sp4 on a dc 3.5k if that's the case. I don't want to hassle with having to top up the batteries every night if i don't have to. Also would it benefit much possibly upgrading to a 14v system over the stock 12?
CJ18 Posted July 19, 2012 Report Posted July 19, 2012 At 1 ohm yes but .5 ohm you would have some voltage drop into the 11s. I would listen to this guy. Something tells me that he knows just a little bit about electrical systems. Speaking from experience, with a 260a alt and wanting to run a dc 5k at .5 ohm, you will want 3-4 XP 3000s in the back. You dont have to charge them every night, but I would charge them once every few weeks.
AMI CUSTOMS Posted July 19, 2012 Report Posted July 19, 2012 I may consider dropping to 1x 18 fi sp4 on a dc 3.5k if that's the case. I don't want to hassle with having to top up the batteries every night if i don't have to. Also would it benefit much possibly upgrading to a 14v system over the stock 12? Just run at 1 ohm, I don't see the issue as long as you do that still gonna be getting plenty of power and they electrical you mentioned will run that no problem, and since you said you won't have it up all the time, you will be fine and you won't have to top off your batteries like you think, just once in a great while is good unless you are playing it more often. Just use some common sense, watch your voltage gauge, if you start to drop below 12 volts back off for awhile then lay back into it, all it generally takes is 2-3 clicks down on the deck(depending on HU) to get your voltage back right then roll back into it. TEAM SOUNDQUBED -- TEAM SOUTH TEAM S.O.B. - Founder & Captain 3x Streetbeat World Record Holder 2017 MWSPL 1st place Mayhem & 4th Xtreme 4 2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4 2015 MWSPL 2nd place Mayhem & 4th Xtreme 4 2014 USACI 2nd place Streetbeat 5 - 162.6 db 2014 MWSPL 2nd place Xtreme 4 - 144.9 db 2013 USACI 1st place Streetbeat 4 - 161.9 db 2013 USACI 1st place Street Q+ - 162.8 db 2013 MWSPL 3rd Kaos2 & 4th Xtreme 4 2011 USACI 2nd place MOD 1001-2k - 160.0 db 2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db 2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest Best score to date 164.4 db - Termlab Outlaw Streetbeat 4 - 161.9 db Streetbeat 5 - 162.6 db MWSPL on Dash Legal door open (Music) - 162.5 db Sealed on dash Legal (Music) - 161.1 db - Termlab THE BLACK NASTY CURRENT BUILD & FAB The Black Nasty (6) 15 Rebuild Log 2012 (4) 15 Walled Sierra Build Log Evo X build log Facebook page The Black Nasty
AMI CUSTOMS Posted July 19, 2012 Report Posted July 19, 2012 And stay on 12 volt, alot more reserve in the batteries then 14 volt batteries. TEAM SOUNDQUBED -- TEAM SOUTH TEAM S.O.B. - Founder & Captain 3x Streetbeat World Record Holder 2017 MWSPL 1st place Mayhem & 4th Xtreme 4 2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4 2015 MWSPL 2nd place Mayhem & 4th Xtreme 4 2014 USACI 2nd place Streetbeat 5 - 162.6 db 2014 MWSPL 2nd place Xtreme 4 - 144.9 db 2013 USACI 1st place Streetbeat 4 - 161.9 db 2013 USACI 1st place Street Q+ - 162.8 db 2013 MWSPL 3rd Kaos2 & 4th Xtreme 4 2011 USACI 2nd place MOD 1001-2k - 160.0 db 2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db 2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest Best score to date 164.4 db - Termlab Outlaw Streetbeat 4 - 161.9 db Streetbeat 5 - 162.6 db MWSPL on Dash Legal door open (Music) - 162.5 db Sealed on dash Legal (Music) - 161.1 db - Termlab THE BLACK NASTY CURRENT BUILD & FAB The Black Nasty (6) 15 Rebuild Log 2012 (4) 15 Walled Sierra Build Log Evo X build log Facebook page The Black Nasty
gotb00st Posted July 19, 2012 Author Report Posted July 19, 2012 Alright I appreciate the advice, Ill go ahead and start knocking things off the list and start putting a build log together.
