I'll see what I can get done with the wire i have. If I need more I'll probably just order some more knu stuff. I like to keep things the same haha. Thanks though!
2002 Dodge Dakota 4.7 club cab - Sold 2004 Audi S4 Avant
- Fi and Crescendo - Stock Bose System
- http://www.stevemeadedesigns.com/board/topic/147725-2002-dodge-dakota-end-of-the-road/?hl=%202002%20%20dakota
136.4 Sealed @ 29hz
137.0 Drivers window open @ 26hz
I got all my 0 gauge ran today! The only issue right now is that I'm still waiting on my fuse blocks to come in the mail, so I'm still running off a 4 gauge power wire...
Took out the seats and center console
This is the kind of mess that I didn't want anymore
You have to take out all the trim panels just to get underneath the rear cargo area...
New ground location. It's where one of the rear seat belts bolts to, and it's under the cargo area so it'll be nice and concealed
4 gauge vs 0 gauge
From the battery...
And down by the hood hinge
From there to the door hinge
Here's the grommet where I'll be running the wire into the cab
Cut a hole in the grommet
Then into the cab!
It comes straight in by the kick panel and then it go right under the door sill.
Ran all the wires into the cargo spot behind the amp. This is normally where the jack and stuff would go, so I need to figure somethin out for that...
I cut a hole through the cargo area to run all the wires out to the amp
Lookin a bit cleaner...
It's a miracle I got all the trim pieces back on right...
Stupid 4 gauge...
Vacuumed it up a bit
And here's how it's gonna sit until I get the fuse blocks in and can actually use the 0 gauge power wire.
That's all for now!
136.4 Sealed @ 29hz
I kind hate u now. :) u got ur damned front seats out... I broke a bolt off in the chassis and didnt realize its a one piece seat... Wouldve made getting the box in so much easier. But very nice job so far bro. Im liking how u ran the wire still tuned
My SPL to SQ Build Log
Vehicle:
1997 Dodge Dakota Ext Cab 4x4 2009 Dodge Journey SXT
5.2L V8 Magnum 3.5L V6
Stock Alt
Equipment:
Headunit- Alpine CDE-147BT
Mids/Highs Amp- JL Audio G6600 Class AB 6 Channel
Sub Amp- Hifonics BRZ1700.1D @ 2 Ohms Taramps DSP3000.1D
Sub- Hertz Hi Energy 12" HX300D SounDrive SDA3 12
Tweeters- Rockford Fosgate Power Series Silk Domes Hertz Hi-Energy
Mids- Dayton Audio Reference 4" Full Range Drivers
Midbass- Silver Flute 6.5" Hertz Hi-Energy 6.5"
Processor- MiniDSP 2x4
RCA- 6 channels of SounDrive HF series
Wire- EB Flex 2/0
-Member of Team SounDrive
tuned in. sweet stuff man! im looking at doing a set up kind of like your's but for my ranger.
Thank you! Haha
That sucks! I've gotten pretty good at takin my seats out and puttin em back in haha. And I'm sure you're 18 will get louder than my 12!
136.4 Sealed @ 29hz
Soo, I'm still waiting on my fuse blocks (Monday is the last day usps said they would arrive), so still no 0 gauge power wire haha. However, I did gain quite a few rattles after pulling out all my panels and putting them back in. Deadener is starting to sound more and more like a good idea every day...
136.4 Sealed @ 29hz
See I shouldve done deadener before the build. can't happen now but cmon get that 0ga working! I wanna see some vids btw
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
Haha yeah. I can pull my truck apart pretty quickly by now if I ever wanna do deadener. I'm gonna try to get a new vid up tonight!
136.4 Sealed @ 29hz
Here's a little video for ya. My truck flexes a little more than the camera shows (which really isn't that much)... but hopefully this will hold you over til I get it all complete!
136.4 Sealed @ 29hz
Fuse blocks!!!!
This one is going right by my amp, it's mounted inside the amp rack
With the cover on
The amp rack does a decent job concealing wires... I also painted it black with Plasti-dip
Nice mess of wires...
It all looks clean though!
Old vs. new
Here's how it will be with the big 3 fuse block. I'm a few feet short on wire to get my big three done, so that will be the next step
All hooked up
For some reason while I was installing my 4 gauge, I thought it would be a good idea to run it through my dash. I had to take out my deck so I could get my hand back there and feed it out bit by bit...
And back to normal!
So that's what I got done today!
I've decided that I'm going to start saving up now for the Fi, instead of the battery (which will be an XS Power d2700). This way, I can get the sub and run it at 4 ohms to break it in. Then once I have the money for the battery I'll be able to wire it to 1 ohm and run it full tilt with no concerns! :slayer:
136.4 Sealed @ 29hz
  • Who's Online   0 Members, 0 Anonymous, 4671 Guests (See full list)
