HELP!! Subs cut out a mid volume
That amp is taking power from a tiny coffee straw seems like it.
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
That's what I'm thinking. In my truck I'm running 2 gauge
2010 GMC Sierra SLE Texas Edition Sky High 2/0 OFC Wiring
2 Digital Designs 1508's Supercharged
Digital Designs Door Speakers
Rockford Fosgate T1500-1bdcp
Rockford Fosgate Prime 300x4
Rockford Fosgate 3Sixty.3
SMD VM-1
XS Power D3400
take the sub box wired at 1ohm in your truck and see what it does...
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
I wanted to do that but the box is bolted to the body of the truck. I will more than likely get him to run new power and ground
SMD VM-1
XS Power D3400
Yeah, I think you are on the right track with the wire...
CURRENT SYSTEM:
  • Alternator:
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
    • Mids RE XXX 6.5c
Build Log
sounds like your starving amp and making it work too hard. give it some bigger wire. 4 gauge i guess and you should be fine. are you sure the 8 gauge is a good brand, reliable wire? cause if its not then that could definitely cause a problem. like socky said its trying to down the drink threw a stiring straw. plus at 1 ohm it is way less efficient than at 4 ohm.
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
From the Crossfire website:
C3 501
Product Features:
· SMD Dedicated Audio Chip Devices
· International Standards FR-4 Double Sided Fiberglass PCB
· Fully 1 Ohm Stable Mono Operation
· High Efficiency MOSFET Power Supplies
· Variable Low Pass Filter
· Variable Bass Boost Control
· Power On & Protection LED Indicators
· Short-Circuit / Thermal / Overload / Under Voltage Protection
· Small Footprint
Doesn't the amp also only accept an 8 GA power/ground connection? For the power and ground I would either give some gauge adapters a try:
http://www.sonicelectronix.com/item_32009_Stinger-SPT522.html
Or use distribution blocks to make the runs of 8GA as short as possible.
Do you have pics of your ground connections?
what kind of speaker wire you running? i had install bay 12g speaker wire and when i would turn my volume full tilt it would cut out and go
into protection mode on some notes, i replaced it with better wire and problum solved, you might have a short
wire those subs to 1ohm and run 4g wire
  • Who's Online   0 Members, 0 Anonymous, 1071 Guests (See full list)
