Just wondering, with a slot port running down the middle and the branching off left and right at the back, does the width stay the same or is it 1/2 the width? I've always done 1/2 the width and now I'm not sure.
So in my sketch-up the port shrinks to 3 1/8" at the back, or does it stay 6 1/4 on both sides:
Input a V on the back wall in the middle when I can. Just make sure the port is not restricted to less than 1/2 width at the corner. You can also cut the end of the port walls at a 45 to take away the point where it turns.
Current system:
1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s
Previous systems:
2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz.
1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
Yeah just not sure about a kerf with a 2" radius. Might be kind of tight.
I did my kerf with a 2" radius. It was a little tight but it came out fine. Check out my build log in my sig for pictures.
  • Who's Online   0 Members, 0 Anonymous, 597 Guests (See full list)
