T-shaped slot port question
Just wondering, with a slot port running down the middle and the branching off left and right at the back, does the width stay the same or is it 1/2 the width? I've always done 1/2 the width and now I'm not sure.
So in my sketch-up the port shrinks to 3 1/8" at the back, or does it stay 6 1/4 on both sides:
Input a V on the back wall in the middle when I can. Just make sure the port is not restricted to less than 1/2 width at the corner. You can also cut the end of the port walls at a 45 to take away the point where it turns.
Current system:
Previous systems:
You got it right. you don't need to add the V thing, but it does help.
More box builds
I'm with captain stupid.
Also had thought about kerfing the 90s at the end, not sure if I got enough skills for that yet, lol
you can kerf it its not that hard to do check out the video on here it is really helpfull. I did my box using that video and it came out great!
Yeah just not sure about a kerf with a 2" radius. Might be kind of tight.
I did my kerf with a 2" radius. It was a little tight but it came out fine. Check out my build log in my sig for pictures.
  • Who's Online   0 Members, 0 Anonymous, 767 Guests (See full list)
