Hey guys i built a box using torrez and well its not sounding as i expected so im wondering if i did something wrong its not hitting the low notes well what did i do wrong?pleas help me fix it
Need more details, like the sub, and your amp, etc.
1996 GMC Sonoma
Four Fi BTL Neo 18's In 2:1 6th Order Bandpass
2 Ampere 5k's @ .5
TEAM FI
TEAM #LITHIUMCANTDEMO
On 10/20/2013 at 0:37 AM, KillaCam said:
Fucking with a Prius driver is like making fun of a disabled kid. Pussies.
What are your amp settings at? The Low pass filter, SSF, etc. Also have you tried different positions with your box
1996 GMC Sonoma
2 Ampere 5k's @ .5
TEAM FI
Posted (edited)
guys the box can only face one direction and that's forward, this is in a Honda Civic so work with me here
the low pass filter on the amp is set to 250
the subsonic is set to 20hz
I checked the impedance of all the subs when wired together an it measured 1.something
well the wire i used isn't the best of wire kinda thin but cud this cause a problem?
also i used a crossover in this system so I'm guessing ill have to post the setting on that as well?
so u guys are saying that these specs ok ?
Edited by johnnyboy
Your box has a port cross-sectional area ratio fault, should be kept 9:1 BUT that should not be the reason of your problem, I would look if you are not receiving a high passed signal from the HU for example.
Also the sub amp should low-passed 60 - 80Hz, the front stage should pick up from there, the subsonic filter is ok at 20Hz.
You also should check the polarity of all the connections to the subs and their coils.
