i think the price per foot ratio is cheaper if you buy full sheets and cut what you need
98 Isuzu Rodeo
Pioneer Deh-6300ub
SUBS
​​*Upcoming* SSA Xcon 18 4th order
AMP
​Banda 3500
Mids/Highs
Pioneer
EQ
Clarion EQS746
ETC.
Two 1/0 run's
KnuKoncepts 1/0 big 3
Shuriken BT-100 under the hood
Shuriken BT-120 in the back
Jesus, you should stock up with it at that price.
And what are you asking for in regards to 2x2's?
On 6/30/2011 at 1:11 AM, 'Ray' said:
Acoustical energy is free. Electrical energy is not.
..... I just realized it was for a 2x4 sheet.... Get your cut sheet made up and take it in. Have them use their panel saw and cut each pice an inch too big each way and then take them home to re-measure and clean them up. Their panel saw will be off a little bit plus they aren't going to be too precise with it. Now you saved money by buying in bulk AND you can fit all of the pieces into your vehicle just fine. And just shaving off an inch on each piece is a lot quicker than doing all of it yourself and working with a huge board.
Thanks a lot guys.
fyi this is the cut list i will go in with:
Cut List
top and bottom: 3x - 38"x22"
front: 32.25"x18.75"
sides: 2x - 21.25"x18.75"
back: 37.25"x18.75"
port: 14.75"x18.75", 10"x18.75", and 3.75"x18.75"
45° corners: 5"x18.75" in the port, 2x - 3"x18.75" in the chamber
bracing: Using 2x2's, cut one 18.75" long and another 20.5" long. Also, cut 2x - 4" triangles to better brace the left side of the box.
Edited by zack_e89
97 Suburban
8 custom PSI Platform 3 18's
The thing is about those small sheets is that they are stored vertical and they warp. So it's a crap shoot trying to find a non warp one.
formerly known as Blue86f150
this sux camel dicks
thanks for the info blue :)
97 Suburban
Not sure how good there mdf and a word of caution stay away from the hardwood plywood if you want to go that route later its complete garbage or atleast over here the layers seperate with a furry. And you can by a full sheet and they usually will rip it down to what ever size you want meaning it ripping it in half , and have carts for easy move to the car lol.
