Bumping for curiosity
Edited by Nikitaaa
2007 M/T Honda Civic Coupe EX
(4) Sundown Audio X-8's
(2) Ampere Audio 3800.1's
(3) Stinger SPV-44 Batteries
(1) Mechman 240
3:1 Ratio 4th order sealed from the trunk
TEAM NWSPL
Best termlab scores to date in Honda trunk:
151.7db legal (official) IASCA trunk 3 class
Best termlab scores to date in my walled Subie:
152.9db legal (unofficial) IASCA advanced 2 class
155db outlaw
No voltage drop is ideal IF you truly have that much current capacity.
If you're suspicious of the drop then it may be that you're not drawing as much current as you should on paper.
Need a clamp.
Is there any chance your voltmeter is defective?
Maybe it's not reading correctly?
Also DON'T use an ohmmeter on an energized circuit. Most DMM's (ohmmeter) have protection but certain ones can be damaged.
To measure resistance, DMMs apply a small voltage and measure how much current goes through the device being measured to calculate the resistance.
If the circuit or device is energized, then it will throw off the reading.
I know not to use the dmm method LOL. Voltmeter is fine, tested against another meter at the rear. Need a clamp. I just want to be sure my amp is at its full potential. If my electrical really is holding up that well, I'm gonna drop to .5 ohm.
SMD Super Seller
My Feedback Thread
yeah maybe the impedance rise its high as hell, my 140A alternator and 2 HC1800 electrical a couple of years ago was holding the voltage like a boss, of course, i wan´t as loud as i thought i could be, changed the box and i got 2 louder, and of course, voltage dropped 2 times lower lol
remember its tough to beat science. if you have 400 amps of current draw at 1 ohm and can only recharge 270 you are going to have a voltage drop unless you are getting stupid rise. im not an electrical engineer nor will i claim to be but there are solid formulas used to determine this.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
What are you wired to? 2ohms? That's why ...drop that bish to .5 and watch power ,spl, and voltage drop increase.... dd amps make most power at or under 1ohm
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
Exactly why i'm assuming big time rise guys.
I guess its all irrelevant, as i'm changing the box again anyway. Done chasing numbers in this car.
SMD Super Seller
My Feedback Thread
No, you see the change in resistance through the coils. You can see what I'm talking about if you've got a speaker laying around.... Hook up positive and negative leads to the speaker terminals, push down on the cone and watch the ohms rise.
i didn't know it worked liked that, thanks man
My current 95 Jetta Build w/
pioneer h/u
2 RD Sonance 10's with flatwind coils
2 Audiopipe apsm 1500.1s
1 Hifonics Brutus Elite 60x4
1 XS d925
1 Stinger spv35
1 1000 amp lead acid
50 ft of 0/1 ofc from Audiotechnix
all powerbass components, and coaxils, 4 sets
buildlog = http://www.stevemead...2-rd-10s-build/
My build for my wife. http://www.stevemead...01-f-150-build/
Single d2, wired to one ohm. Adding a second sub and considering .5, also got an SAZ3500 on the way, sold the M3a and Mayhem.
SMD Super Seller
My Feedback Thread
i will let you guys know how wiring the M3a @.5 ohms goes since i will be doing it with kens old M3a!! just bought it
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
  • Who's Online   0 Members, 0 Anonymous, 2712 Guests (See full list)
