is this possible? i think the guy i bought the subs off talked me into buying 2 ohm subs instead of the 4 ohm subs like i planned
i know you can wire a single 2 ohm sub to 1 ohm, but can you do it with two? please help, need to know so i can return if not
down rpping vanderbilt. 30 miles from victoria. i own the 3rd loudest setup here out of 3. but i did put together all 3 setups
strapping 2 amps together ? like bolting them next together? using bungy cables to hold them down? or wiring separate amps to each sub
2 2ohm dvc can eityher be 0.5 or 2 ohms or 8 ohms
http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=2&I=22
Edited by Maebros
HU: Pioneer AVH x5800BHS SP Amp: AQ 120.4 Front SP: Hertz Hsk 165 Rear SP: DD cxs 6.5 SW Amp: Crescendo BC2000d SW 2 DC level 3 12" Electrical: Stock alt for now XS D2400 XS D3400 Knukonceptz Kolossus Second skin damplifier
On 8/8/2012 at 4:50 PM, Brandon15zzz said:
I heard he actually graduated college with a 4.0 gpa. Seems pretty gangster.
On 8/29/2012 at 12:25 AM, ILoveBass21 said:
he could blow a sub powering it with a potato.
This is wrong. a single 2 ohm sub (SVC) can only ever be 2 ohms. if you have 2 on the other hand, you can do 1 or 4ohms and thats it.
2 DVC 2 ohms subs will be able to wire to .5ohm, 2ohm, and 8ohms. as said above.
i didnt put the .5 ohm cuz you prob wont do that lol. and i didnt put 8 ohms as why would you do that as well
Edited by Mikey Bates
yeah there dual voice coil, sorry forgot that
They cannot be wired to 1 ohm. I wonder why the guy tried to talk you into these. Did you tell him you wanted to wire to 1 ohm?
