About a month ago i had the check engine light come on but then it goes off.
So i took it into the shop the o2 sensor code came up they replaced it i get my car back and bam its back on again.
i call the shop they say it might be a faulty sensor so they put in a new one again and bam its back on again.
Right before the light comes on i can tell cause the car starts to putter a lil bit like its not getting fuel.
Just wanted to see if any one out there had some ideas on what else it could be its a 2006 ford explorer
2015 F-150 Platnuim
Sounds like a fuel pump if its sputtering and throwing codes
Team MaxRetribution
Si Vis Pacem Parabellum
Maybe a probelem in the wiring to the o2 sensor. The wiring that ran to my MAF sensor had a problem in my mercury mountaineer. The connector was the culprit. the wire wasnt crimped very well where the pins slide into the plastic outer piece and it would rattle/move so every once in a while it would throw a code and it would be for the maf.
MY BUILD *****http://tinyurl.com/gmcbuild*****
Vehicles
2005 GMC Canyon
CB1000r - Currently where any future funds are going. (exhasut,bazzaz, ohlins shock, screen, etc.)
crf250r - Used to be race bike..now I just trail ride..practice at the track on it.
CH80 - Daily beater (when nice weather)best 150$ ever spent. 100+mpg
Sold to:
Skullz - pstone11 - Leo1103 - Volvo 63' - pavelpardo - imnew59585
Shower farts still piss me off.
I think theyre pretty neat. When the water runs down your crack as you let one out... its like shitting in a crockpot.
it only takes a few misses for that light to come on. give her a tune up, run through some injector cleaner and see if she cleans up for ya.
She had a full blown tune up when i had the sensor replaced the first time wire, plugs,fuel filter ,trans brake and coolant all changed
2015 F-150 Platnuim
It also sucks cause the check engine light is off right now so they said i cant even take it in till it comes back on witch i random
2015 F-150 Platnuim
Seems like you should take it to a different shop. Just caus the light isnt on doenst mean that they can see what is going on. The computer has a memeory and will in the history. They can also see the "freeze frame" of the data when that light was triggered.
Do you know what the exact code number was? That will give me a better idea of were to start. Looking but at the same time it could be a bunch of different possiblities and would need a scanner hooked up to the truck to tell you what I would do first. I doubt you have a bad O2 sensor. Depending on the code.
Thats cool. Im way too old to be upset by shit like that. Your name is winston. Your own parents hated you even before you were born.
My penis is bigger than your penis
I'm far from loud and my roof/headliner flaps around like Adam's ass on a windy day. I think it depends more on the structure of the vehicle.
check your Mass air flow sensor (usally right after the air box)
http://www.stevemead...f-system-build/
2001 VW GTI with a 1.8T motor
BIG 3
Pioneer AVH-4200DVD DOUBLE DIN HEAD UNIT 6 - 4 VOLT PREOUTS
RF T1500-BDCP (running at 2 ohm)
RF T400.4
RF T1 D212 x2 (in ported box)
RF 1/0 TO 4 GAUGE distribution block x 2
all stinger wires
200a alternator (SINGER ALT)
RF T2652-S (6.5 MID BASS AND 1" TWEETS in front and rear)
KINETIC HC 800 BATTERY (Front)
KINETIC HC 1200 BATTERY (BACK)
120ft of 1/0 stinger blue and clear matt
20ft of 4 gauge stinger blue and clear matt
30ft of 8 gauge stinger blue and clear matt
100ft of 12 gauge stinger speaker wire black
P2195 O2 snesor signal biased/stuck lean B1S1
Description:
A heated oxygen sensor inticating lean at the end of a test is trying to correcto for an over-rich condition. The test fails when the fule control system no longer detects switching for a calibrated amount of time.
Possible Causes:
Electrical:
  • Short to VPWR in the harness or HO2S
  • Water in the harness connector
  • Open/shorted HO2S Circuit
  • Corrsoion or incorrect harness connections
  • Damaged HO2S
  • Damaged Powertrain control module (PCM)
Fuel System:
  • Excessive Fuel Pressure
  • Leaking\contaminated fuel injectors
  • Leaking pressure regulator
  • low fuel pressure or running out of fuel
  • vapor recovery system
Induction System
  • Air leaks after the mass air flow sensor
  • Vacuum leaks
  • PCV system is leakiing or the valve is stuck open
  • Improperly seated engine oil dipstick
EGR System
  • Leaking gasket
  • Stuck EGR Valve
  • Leaking diaphragm or EVR
Base Engine
  • Oil overfill
  • Camshaft Timing
  • Cylinder compression
  • Exhaust leaks before or near HO2S
Edit: Without hooking up to the scanner and seeing the fuel trims and live data some of the above would be hard to diagnose.
Edited by Keith77
