custom BL18 box built to spec sounds like crap
ncc74656
siucsa, i am trying to find what others have been doing with there build while at the same time trying to check on the box that is currently built. I am saying that to out right dismiss the box builder as a hack may not be the best way to go about figuring things out. rather than just saying he sucks i want to hear why, what should be done differently, and what others have done. i say this as he is not some guy i met on the street but someone who came highly recommended. I am trying to formulate my own opinions and figure things out for myself at the present time.
nothing, gutted
i believe (i may be wrong here) that the additional port was added after the sub failed to perform to expectations and the assumption was lack of air flow. i am going to discuss some options with the builder shortly. i am mostly trying to understand all the reasoning behind each choice and make educated decisions on my box.
nothing, gutted
See if you can contact joe x on this site, he is very helpful in box designing specs.
Psh...helpful in providing box specs, but not always knowing they will work or not.
what are your max dimensions, ill see if i can't whip something up for you real quickly, just gotta switch from Mac to PC...time to restart the computer, once you post your max dimensions.
A port is there to give desired port area or the driver(sub) needs, PLUS get you to a desired frequency. Adding a port without doing any sort of math or reasoning doesn't make sense. KNOWING prior that I'm going to,"add another 12" of length to my port will increase my port area to 14 square inches per cubic foot of airspace, while at the same time, raising my tuning frequency by 6 Hz" is the best approach.
^^^thats obviously a generic explanation and doesn't apply to your situation. It's an example of what a box builder SHOULD be thinking like.
Seems like he designs boxes as well as he draws circles.
under construction
I hate People with crappy primered cars rolling on hubcaps that are louder then me.
u hate c-fizzy?
You mean ovals, hahaha. I saw the same thing, not to mention the circle for the sub itself.
my measurements are as follows. rear seat of dodge ram (quad cab). 21" from back of seat to front passenger seat in a some what mid lateral position and slightly tilted back. 28" from rear seat to bottom of rear window, 36" width wise to give a bit of room in the back seat for tool boxes. these numbers can be stretched and moved a bit if needed.
nothing, gutted
  • Who's Online   0 Members, 0 Anonymous, 4663 Guests (See full list)
