jakeryan Posted July 27, 2012 Report Posted July 27, 2012 Basically, I really would like some ideas on the best painting method to get a finish with heavy texture like all pro audio subwoofer enclosures. I need a finish that can take a beating from being moved around & such. Thanks! B.T.T.M -Jake Ryan
Crandis16 Posted July 27, 2012 Report Posted July 27, 2012 bedliner can take a beating. it doesn't look too bad and has a grippy texture too My Red zx2 Build Log My Black zx2 Build Log My Red zx2 UBL
AA98hoe Posted July 27, 2012 Report Posted July 27, 2012 Rhinoliner is best bet..or use resin the texture paint after words TEAM DC AUDIO VEHICLE:98 chevy tahoe 2wd 3-4 drop HEADUNIT:alpine 9886 PREAMP:arcaudio FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door KICKPANELS:jl audio 5 1/4 REAR DOORS: dd components 6 1/2s HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV SUB AMP: 2-dc7.5s ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket WIRE:10-runs 0g front to back BATTERIES:6-d1400s TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
IBleedMusick Posted July 27, 2012 Report Posted July 27, 2012 bedliner can take a beating. it doesn't look too bad and has a grippy texture too ^Bedliner is probably your best bet if you want paint that isn't easy to scuff. Either that or use a textured spray paint like a stone texture. 2013 Dodge Charger Build Log 1996 Ford Explorer XLT 5.0Build Log 2005 Honda Civic LX Coupe Build Log SMD SUPER SELLER!!!!My Selling Feedback
jakeryan Posted July 27, 2012 Author Report Posted July 27, 2012 The bedliner looks like my best bet so far actually. Plus it has the exact look I'm looking for B.T.T.M -Jake Ryan
RooTxBeeR Posted July 27, 2012 Report Posted July 27, 2012 How much would someone say it would cost to cover a box with rhinoliner? like a 4-5cu gross enclosure. On 11/20/2012 at 8:54 PM, AMI CUSTOMS said: Turned mine up today at a light, guy next to me his steering wheel started moving and he looked over at me like I was a magician lol. On 5/9/2012 at 8:45 PM, skittlesRgood said: fuck the plating. look at what the main metal used is. you could buy unicorn blood plated terminals but if its just covering up dog shit, whats the point On 4/10/2013 at 12:26 PM, mrd6 said: I'll admit, half way through sanding that fiberglass in the rain and cold while I was all itchy I was definitely starting to question why i was doing this haha Soon To Be '04 Ford Escape US Alternator 280A Hairpin D4800 Under the Hood (6) XP3000's in Rear 1/0 SHCA & XS Power 4 runs to back TORK2 kit from Tony @ CE Auto Supply Pioneer DEH-80PRS DD AW6.5 (2) per door *Tweeter Unkown* DD SS4a & C3d (2) SCV4000 @ .5Ohm (2) 15" Sundown Zv5
jakeryan Posted July 27, 2012 Author Report Posted July 27, 2012 How much would someone say it would cost to cover a box with rhinoliner? like a 4-5cu gross enclosure. I could honestly not know about rhinoliner but bedliner is like 30 or something dollars a can. B.T.T.M -Jake Ryan
Crandis16 Posted July 27, 2012 Report Posted July 27, 2012 How much would someone say it would cost to cover a box with rhinoliner? like a 4-5cu gross enclosure. I'm gonna guess 75? I had 2 home audio towers done and cost about 150 My Red zx2 Build Log My Black zx2 Build Log My Red zx2 UBL
SnowDrifter Posted July 27, 2012 Report Posted July 27, 2012 Sand it with ~40 grit sandpaper and paint with 2 coats of herculiner/rhinoliner/etc (not the shitty duplicolor spray stuff) using a sponge roller. That's what I do and it comes out tough as nails ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
mitchell830 Posted July 28, 2012 Report Posted July 28, 2012 when i got my bedliner done in my truck (line x) i had them do a sub box for 1 15 and they charged me 50 bucks. it looked great
