Turn the DMM to AC Volts, turn on music, and measure the volts at the speaker terminals on the amp.
My name is AdamThis is my Civic Build.7" Samsung Tab 2Kenwood KDC-X896Clarion EQS746Sundown X-15DC 3.5k @2ohmHatersGonnaHate's 02 Civic UBLELD Bypass for Honda Civic/Accord/FitDon's Jeep Grand Cherokee Rebuild
N8ball2013 - i think you'd stick your dick in a blender if it told you it was 40 wtih two kids your age. lol
srp365 - If posting were picking up bitches, I'd be going home single tonight
looks like tony montana sneezed in your car.
is there a way to check and see if my amp is putting out to the sub wires?
dmm on ac voltage, and on the output of the amp would be what i would say.if you get a reading while you have something playing, you have a signal fromthe amp. that doesnt say how good the signal is, just shows that the amp is putting out
edit: ninjd
Edited by crispy_chick3n
This page is crispy_chick3n approved.
© crispy_chick3n inc
edit: ninjd
dmm wasnt reading anything out of the amp speaker outputs >:(
So you have no voltage drop when playing full tilt? I highly doubt that and is your amp 1 ohm stable?
Subs cut out for a few resons
Voltage drop
Wrong ohm load
Wired wrong
Bad ground or power connections
Pushing the amp past its limits
Having a fucked up sub/ tinsel lead
Wich one of those are you guilty of?
Edited by Team Bassick (ALPINE)
The amp has power? Check the fuses?
Voltage drop
Wrong ohm load
Wired wrong
no I mean I don't have bad voltage drop..I stay above 12.7... everythings wired correctly sub leads are all good...I'm guessing at this point its the amp...I mean idk what else to assume..Even though I've never played it clipped, and have ran it at 1 ohm for quite a while...I don't even play em full tilt for more than 2minutes...
