9/10 most people are happy with a well worn trigger. If your gun has under 1000 rounds yo may benefit from simply putting lapping compund on the hammer and sear and speeding up the process of normal wear.
I have a Stag Arms M4 that took a whole bunch of rounds to break in. At first the trigger felt like a ton of bricks to pull, but it's much easier now after putting rounds down range. How long/ how many rounds have you fired for this AR?
I may not slam trunks anymore....but my trunk still slams.
I dunno probably 3-4000 if i had to guess
Team MaxRetribution
Si Vis Pacem Parabellum
if you want a mid range trigger and not something super light look into the spikes battle trigger.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
are you proficient at taking your FCG out?
Whats an FCG? I know what a BCG is
I mean the lowest i would think of running is probably 3lbs... I have a 2.5lb trigger on my bolt action 270 and I LOVE IT just not sure if i should run that light on my AR
Team MaxRetribution
fire control group.
your trigger hammer etc. ive got a 3.5 on my lrt sass and thats about perfect for its application. a little heavy and could probably come down a little bit more. I did like the spikes battle trigger though its on my second lower.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
fire control group.
So the 3.5lb trigger gives you some resistance but still breaks smoothly right?
I know with the 2.5lb trigger on my 270 Hunting rifle that if you sneeze on the trigger its going off lol
Team MaxRetribution
yes it does
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Nice... I am going to look into the Spikes and some other options to see what i can find between 3.5-4.5lb trigger
Team MaxRetribution
I wouldn't waste my time with the spikes. It's a standard hammer and trigger with nothing more than a nickel boron coating. They rate it between 5-9#
Rolex you sicken me.
Just let me finish my pie
~ Juice
