Box is going in 2001 tahoe. I think its to big for the amount of power, but would work if I used a aq2000 on each instead of strapped. its an option, and havent figured out of I want to strap or not. any input is appreciated.
H:30
W:41
D:28
Port
H: 5
W:38
L: 32
1 extra baffle
wood thickness : 1.5
TF-37.99hz
Net Volume 7.73 ft3
port area- 190.in2
gross volume-14.84ft3
port volume-4.72ft3
Edited by Cutdeluxes1
Well, your enclosure dimensions do not match the box spec, besides that, using 1.5" wood is not necessary and would make the box very heavy, just some crossbracing will suffice for a solid build.
The best way to run the 2 2200D is strapped to avoid the need of gain matching or a separate chamber enclosure, subs coils in series subs in parallel for a 2 ohm total load (for dual 2 ohm subs).
Those number came straight off torres. Would do a screen shot but can't figure out how. Very heavy is ok to me, means no one will take it! I figured strapped would be better for single chamber.
Just want to make sure that im not choking the subs or to much airspace due to the amount of power Im putting to them.
My bro in law runs d9 at .25 ohm on 2 hdc3 15s alums coil with no problem in 7.8 cubes 17 sq in of port per cube. So your power won't be an issue. For that power I would do 9 cube net with 17 sq in of port per cube tuned the same. Do you have alum or copper coil hdc3?
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
yeah x2 on too much port area. thats 24.5sqin per cube LOL. drop it down to around 17 like AMI said.
Ill be running copper.
I thought the port was big, but i dont know how to make it smaller and keep the tuning high. im looking for tuning between 36 and 40.
<xBoxHeight>21</xBoxHeight>
<xBoxHeight2></xBoxHeight2>
<xBoxWidth>48</xBoxWidth>
<xBoxDepth>21</xBoxDepth>
<xBoxDepth2></xBoxDepth2>
<xPortHeight>8</xPortHeight>
<xPortWidth>14</xPortWidth>
<xPortLength>16</xPortLength>
<xNumOfPorts></xNumOfPorts>
<xPortDiameter></xPortDiameter>
<xSubDisplace></xSubDisplace>
<braceDisplace>1.5</braceDisplace>
<xBaffleThickness>1.5</xBaffleThickness>
<xCommonWalls>1</xCommonWalls>
<numOfBaffles>1</numOfBaffles>
<externalPort></externalPort>
</Data>
This is what i got now, with .75 wood thickness
  • Who's Online   0 Members, 0 Anonymous, 378 Guests (See full list)
