TrentonLong Posted August 5, 2012 Report Posted August 5, 2012 My brother is running my dual 400 amp and sony xplod sub, And he is running a boss 900 rms sub and a 400 rms pioneer amp. The amps start turning on and off. He dose not what to get a bigger alt! So what can i do to up the voltage and amps? Would an Isolator work? Sorry for the crap of spelling, Tired as fuck and need to go to sleep:( Regards Trenton
Swordlordboy1234 Posted August 5, 2012 Report Posted August 5, 2012 Sony amps, mismatch subs, should I ask if you wired correctly? Did you ever think of a big 3? Are you even using the right size wire for your -Sony amps- My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37 My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/ 2016 Mazda 6 Touring JL Fix 86 - OEM signal correction B2 prototype DSP 6to8 B2 Ref63 - 3 way active set 2 B2 Class H quattro's 1 B2 Zero.5R @.5 2 B2 HNv3 12 d2 B2 SLIP40 - Lithium in the trunk Northstar Group 35 under the hood 100ft 2/0 welding cable 30ft 4ga welding cable 20ft 8ga welding cable All stinger OFC speaker wire Soundrive custom RCA's Tons of attention to detail.... Can it be perfect?
Guest Posted August 5, 2012 Report Posted August 5, 2012 nothing should be turning off with small amps like that. its more than likely the following: 1) loose grounds. or grounds that arent bolted to thick metal like a strut tower, with the paint sanded off around where the lug touches the metal 2) loose power wire. or the connection at the battery, or fuse holder, or the amp itself 3) loose wire lugs on ground or power wire 4) frayed wire on the + and/or - power terminals on the amp that are touching each other. a single strand of wire touching + and - together can cause this. 5) messed up amp settings, like gain, bass boost (which should be off), etc edit: x2 on what sword said. subwoofers may be wired too low (or maybe the wrong way) for the amps to handle.
TrentonLong Posted August 5, 2012 Author Report Posted August 5, 2012 Sony amps, mismatch subs, should I ask if you wired correctly? Did you ever think of a big 3? Are you even using the right size wire for your -Sony amps- I know how to wire it all right, it is the power, It all works but when i set the gains on both amps about less then 1/3 up the lights on the amp go on and off! Tomorrow i will use the multi meter it and see just to make sure it is, There is no upgrades to the electric system at all.BTW it is a dual amp not a sony, lols The fuses are 50 amps and 30 amps. The truck is a chevy 1500 so idk what the alt output is. AND the truck was off when it did it so could that be the reason why it did it?
Tarball Posted August 7, 2012 Report Posted August 7, 2012 Do big3, make sure all connections and solid and proper ...as stated. You have to do the basics first. CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db
HunterJohnson Posted August 7, 2012 Report Posted August 7, 2012 Run 4 gauge power to the back amps. And ground to chassi. Also ground the front battery to chassi. Shudnt have voltage drops after that Scion tC SQ BuildiPad mini, lots of fabrication, daily drivenFord Explorer C Pillar Wall Build Just a cheap car to destroy with bass
severancej Posted August 8, 2012 Report Posted August 8, 2012 Don't run the subwoofers with the truck off, its asking for a problem because the voltage drop is very bad 98' dodge ram 140A alt Big 3 XS D2700 JVC kd-r310 Rockford T500-1BDCP 2 Sundown E12 Ported 4cubes 35hz Rockford P400-4 2 Infinity reference 3way 6x9 2 Polk DB 5 1/4 2x layer dynamat all doors
k3n12ock Posted August 8, 2012 Report Posted August 8, 2012 What ohm load is each sub and what are they wired to? 05 xB - (2) EVIL 18s - (2) BC3500s - NO WALL Channel 1: http://www.youtube.com/k3n12ock Channel 2: http://www.youtube.com/MrK3n12ock2
