Need advice on subs/box for a tractor trailer
Phototini_xB
If I could get away with an 18" in a ported box with the port facing the front of the bunk and could cut a whole in the separator to let the port fire out into the cab would that pound harder?
Yep it would....
98' dodge ram
140A alt
Big 3
XS D2700
JVC kd-r310
Rockford T500-1BDCP
2 Sundown E12 Ported 4cubes 35hz
Rockford P400-4
2 Infinity reference 3way 6x9
2 Polk DB 5 1/4
2x layer dynamat all doors
Sorry for the stupid questions but it's been about 10-12 years since I've had a decent system. And back then it was in a Ford Bronco II. And if I can't cut the hole in the bunk wall for a port would a sealed 18" or two sealed 15's be a better bet?
id say the 15s. never ran anything before this build but ive heard sealed and they are really quite. they do get decently low tho
My SPL to SQ Build Log
Vehicle:
1997 Dodge Dakota Ext Cab 4x4 2009 Dodge Journey SXT
5.2L V8 Magnum 3.5L V6
Stock Alt
Equipment:
Headunit- Alpine CDE-147BT
Mids/Highs Amp- JL Audio G6600 Class AB 6 Channel
Sub Amp- Hifonics BRZ1700.1D @ 2 Ohms Taramps DSP3000.1D
Sub- Hertz Hi Energy 12" HX300D SounDrive SDA3 12
Tweeters- Rockford Fosgate Power Series Silk Domes Hertz Hi-Energy
Mids- Dayton Audio Reference 4" Full Range Drivers
Midbass- Silver Flute 6.5" Hertz Hi-Energy 6.5"
Processor- MiniDSP 2x4
RCA- 6 channels of SounDrive HF series
Wire- EB Flex 2/0
-Member of Team SounDrive
I kind of figured two 15's would out do an 18" just because there is more woofer area. Just wanted to ask because I've never even seen an 18 in person before. Does it matter what direction the subs are firing though because with 15's they will most likely be firing upward.
i think no matter what ull have them firing upward. and what was the under the bunk u had to work with? maybe get a 18 or a 15 in a sixth under there if the room is there
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
Yeah with either an 18 or two 15's they will be firing up. I can do two 12's firing front though, just not sure if I'll get the feel I'm after in my price range with 12's.
if ur at 12 try the obsidians i hear they are good and can take over rated and do good in bp boxes. maybe someone with them can chime in tho. but whats ur dims u have under there?
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
The dimensions are roughly 18" H x 70" wide x 36" deep. But I have to wait until I get the truck to get exact measurements. That's just off the top of my head from the last frieghtliner I had. And my budget will be roughly 1000 bucks for sub/s, box and amp. So basically I want what ever will be the loudest don't really care what size woofers I end up with.
2x z15v3 if it's 1k for subs only
But it's not so
2 sa15 on a sax1500d for $800 or 3 for 1k
4x sa15 on a brz2100 of $1060 or 3 for $860
Or 4 on a brz2400 for 1099
  • Who's Online   0 Members, 0 Anonymous, 1103 Guests (See full list)
