XS Power
How many D1400s would it take to properly power 2 DC 9ks with 2 400a alts dedicated just to the 14v side? I have 10 now and am trying to figure out how many more I may need to add.
CJ, I came up with 14 in my calcutions, you need around 1000 amps of alt to run that setup for music, so you have 800, you need 200 more amps worth to run that gap. I figured 4-5 more from what you have now will do the trick.
Also you running below 1 ohm? if not you will be good with the 13 you came up with, little to no voltage drop from 16 v range.
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
Dang Nathan looks like I need at least 6 more batteries.....
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
I can drop to 13.3 at idle full tilt with 6 xs 14v batts an 1020a of alternator
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
1500watts per D1400 for competition use. 12 total would do the job and anything over that is just buffer for extended periods of play time.
Again AH means NOTHING in car audio applications.
Guess not bc 12 d1400's would be 600ah plus 800alt power. Is only 1400 not 2k like I calculated
Scion tC SQ Build
iPad mini, lots of fabrication, daily driven
Ford Explorer C Pillar Wall Build
Just a cheap car to destroy with bass :D
