It wont harm your vehicle at all by having it towed that way. My truck, my dads truck both have 4 wheel drive only difference is mine is newer and has the neutral position on the 4x4 switch to disengage the entire drive shaft where my dads doesnt. He towed his with the rear tires on the spoons and the front tires on the ground without any problems. Mine is a pain to tow like that unless you have a wheel lock or wrap the seat belt in and out on the wheel because i dont have a wheel lock like my dads tahoe does so you can spin the wheel around with the keys out of the ignition.
2004 GMC Envoy1 XS power S3400 batt under the hood and 4 XS Power D3100's battery installed in the rear by the amps0 gauge power wire from front to backAlpine iva-w205 touchscreen dvd/cd/mp3/ipod/am/fm/gps headunitSundown Audio SAX-200.4 amp for my mids and highs8 gauge speaker wire from amp to woofer270 amp Mechman AltRockford Fosgate T1652-s component speakersRockford Fosgate 3Sixty.2 sound processorRca's from Rockford Fosgate and Monster Cable14 gauge speaker wire for the mids and highs1 18" Ascendant Audio SMD Dual 1 ohm with custom Black & Blue carbon fiber and hand signed dustcapBox: 5.66 cubic feet net volume box tuned to 30.13Hz with 1.5" wide wooden dowels and 1.5" thick baffle1 DC Audio 5.0k amp wired to .5 ohms nominal with an imp rise of 1.35 ohms for the single AA SMD 18"Future Vision 8000k 50w bi-xenon projector HID's with 4300k 35w fog lightsLink to my build: Buildupdates/progress
Thanks guys! I just was not sure what to think about it.
2006 Silverado Ext. Cab
6-15" SSA ZCONS
4th Order Blow-Through
Pioneer AVH-P4200dvd
American Bass VFL 1100.1 12 volt
6 C&D Batteries
2-350A Singer Alternators and Stock Alt
DC Power Triple Alt Kit
MLA Module
3 Runs of 1/0
2 Sets of Boston Acoustics 6.5 Pro Components
Boston Acoustics 2-channel
Lots of Sound Deadener
....Build still in Progress...
  • 5 weeks later...
you are pretty safe towing from the rear like that.
even if the transfer case was engaged it wouldnt matter as the gears are still spinning and moving the oil around lubricating everything.
thats why you cannot flat tow an auto without removing the driveshaft as the oil pump is on the front of the gear box and is driven by the motor and there is no oil being pumped around to lubricate everything and apply clutches and bands to select gears when driven from the driveshaft end.
this is why you cannot roll/tow start all autos (some have pumps on the back too for this purpose).
so as long as your car isnt auto or in 4wd you should be right.
99 Ford Courier, 2 x Rockford Fosgate P3SD410, 1 x Rockford Fosgate T1000.1 bdcp, 1 x Rockford Fosgate T400.4, 2 x Option Audio Splits, Kenwood KVT-747DVD and no room to install any of it
Wish List : 2 x Polk Audio MM6501, Rockford Fosgate 3Sixty.3, Rockford Fosgate RFC10HB
If it wont go, force it. If it breaks it needed replacing anyway.
the main concern is not the transfer case but the trans, when your truck is not running ,the pump is not circulating trans fluid in the trans, gm wants you to put the transfer case in neutral so it disconnects from the trans and while the wheels and diff are turning, its not turning the trans output. for short distance low speed tows, say for a couple blocks or 1/2 mile, it wont hurt it, if the transfer case can not be put in neutral for longer distance tows, then the drive line must be removed to prevent damage to the transmission. so how far did they tow it?
hope this helps.
and any tow truck driver worth his salts knows this also.
hope this helps.
this ^
Since you decided to buy a chevy, you have an independent front suspension with unibearing front hubs. Generally in the 4x4 community, this is regarded as a very weak setup for a truck. Your unibearing front hubs are always locked in, meaning that the front driveshaft will turn when the wheels turn, and there is nothing you can do about it. This will cause excess wear on your differential, and the unibearing hub type is generally much more expensive to replace than a set of lockable hubs. EDIT: where I am going with this is that if you would have gotten something with selectable hubs, you could have just left the hubs unlocked and not had to worry about the front driveshaft turning. Ever.
Onto the point. As James said, the transfer case itself can handle the front driveshaft turning just fine (because as long as you are in 2wd, the front driveshaft is not "hooking up" to anything in the transfer case, it is in neutral. It is not until you engage 4wd that the transfer case will "hook up" to the front driveline.
Shifting the xfer case into neutral disconnects the input gear of the transfer case from the output shaft of the tranny. Do this and you can tow your truck with the back wheels off the ground no problem.
The biggest thing you will have to worry about with your transfer case are the solenoids. The newer electronic shift Chevys are notorious for blowing these things out. (Read: get a manual shift transfer case)
Either way what the tow truck driver did is fine.
Source: Parrot Asteroid Smart
Processor: Digital Designs X1
Amps: Soundstream Ref 4.920 + Soundstream Ref 4.400 + Soundstream DTR 3400
Front stage: Hertz 165xl + HL 70 + HT28
Rear fill: Hertz 165xl
Subs: 2 SA-12's
3-way active ftw
