Posted (edited)
So im trying to plan my new build. Im thinking about the Sundown Z v.3 18 inch sub to run with my Hifonics BRZ 1700.1 i only have about 6 cubic feet to work with. would that sub sound good in a ported box tuned to around 29-32 hz? Or is there a better 18 i could go with?? here are some pictures of my current build. http://s1249.photobu...%3D084ea3d2.jpg the box is 4 cubes tuned to 32 hz. i get a fair amount of windsheld flexx with it on only 600 watts(4ohm) So any suggestions would be greatly appretiated!
Edited by Msg4lifesucka
Posted (edited)
or a dc
Level 4 or 5?
The Q and the DC work in larger enclosures ( about 6 cubes and above) the Zv.3 works in 4-5 cubes that's a big difference when lacking space, if going with those other brands better a couple of 12s which will fit in 4.5-5 cubes comfortably but two subs will cost more and need more power.
Edited by Joe X
Meserments are a must
Just because you have 6gross doesn't mean you'll fit either,
Post some meserments, work out what you have and pick a sub bassed on that,
Then you will have something that you no will fit and work in the elected space
Posted (edited)
or a dc
Level 4 or 5?
where did you hear this? have you used them in smaller than recommended enclosures?
yes they work in larger enclosures but can perform extremely well in small enclosures too. level 5 18s can be ran down to 5.5 cubes if paired with the right power levels. I ran one in 5.5 and it worked wonderfully, just 3k wouldnt really move it too much.
edit: with only 1700 rms and 6 gross, i would look into lower powered 18s in the 1000rms range so the extra power in the smaller box. Getting an XL or level 5 would be pointless anyway on that power in around 5-5.5 cubes.
Edited by ChevyBoy95
or a dc
Level 4 or 5?
Yes you have a point there, i was looking at the Audio Que HD318. rated at only 1000 watts, not too bad?
