my cabin peak frequency is 42hz....
How did you find it?
term lab...
https://photos.google.com/photo/AF1QipP7rjav9cD9UFdAYBJmz4M4LoNlF26ng1xhAf4Uhttps://photos.google.com/photo/AF1QipP7rjav9cD9UFdAYBJmz4M4LoNlF26ng1xhAf4U
2013 DODGE CHALLENGER R/T
SUNDOWN ZV4-18
CRESCENDO 3.5K
PIONEER AVIC 5300 NEX
ALPINE TYPE R 6.5S & 6X9'S
ROCKFORD FOSGATE 1.5" TWEETS
5 C&D TECH BATTS
so 3k for a single 18
make some test boxes. one with sub and port facing the same direction and one with sub forward port side
this will allow you to test every sub port combo except sub forward port back (usually not good unless in a hatch, crx)
once you find which orientation the vehicle prefers start building boxes.
i like to start big and shrink the box until you stop gaining.
burp boxes are trial and error. so start trying
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
thanks alot guys i located a local basshead with a term lab i can spend some time building...thks again..
SUNDOWN ZV4-18
CRESCENDO 3.5K
5 C&D TECH BATTS
42 hz? seems way too low if you ask me, anyways, try to get some more power and definitely wiring the amplifier low as hell, i would do something like 4.5 cubic feet and 3 6" aeros facing side with the port facing up, that would be a good starting point...
  • Who's Online   1 Member, 1 Anonymous (See full list)
