CJs F150 2/19 New videos posted pg 70. 1080p 60fps!!!!
As promised, PICTURES!!!!
First task for the day was to get the grommets installed so I can run wires safely into and out of the cab. I had perviously just drilled holes and used deadener to keep the edges from cutting the wire. Not anymore!
Wire before and after installed techflex
I decided to run a new power wire from the front 12v to the back where I will have 2 D3100s.
SO my rear sliding glass likes to rattle so I figured I would try to fix that before I put the back of the wall back up.
And for those who asked about the battery rack and amp rack. I still have to pull the batteries out and drill more holes in the buss bars for all of the exra runs I am going to need. You can see the space that I left for 3 more and then there is a d3400 in the back right corner that is coming out and the 14th 1400 will go back there.
