CJs F150 2/19 New videos posted pg 70. 1080p 60fps!!!!
Time to buy.....zip ties!
2003 Kia Sorento
Team Subsonic Lows
Team Bassin' on a Budget
i know im a little late to the party here but looks so sick man! quality work! question though, do you plan how to run all the wiring and everything before you build or do you just kind of figure it out as you go?
can't wait for more updates!
~ If it was easy, everybody would be doing it ~
Ok so since the question was asked, wiring is on my mind at the moment. I have a very detailed plan and order that everything has to be done for the rest of the build, so here it is starting with the next thing I need to do.
1) Run 4ga wire into the box for the subs.
2) Install white panels inside ported chamber
3) Assemble and install subs
4) Wire subs
5) Install RGBs
6) Install front baffle
7) Install DC Mirrored plexi logos inside of box
8) Install Plexi windows into loading wall
9) Install front trim panels
10) Install 2 d3100s in cab
11) Install and wire 200.4 on each side of wall
12) Install Custom Relay Panel
13) Run RCAs and Speaker wire to each 200.4
14) Build center console to house 360.3, 2 10s, 2 VU Dins, 2 SMD Volt Meters, and all switches
15) Install door panels
16) Tune 4 channels
17) Install amp rack in bed
18) Wire up 2 9ks
19) Whatever I forgot in the first 18
20) BASS TIME!
Yeah so there was a small problem with my plans for the Level 5 15s, so I am having to change up and go a different direction.
