Just realized that I haven't posted all the pics.
Here's a few more.
Here's how the sealing surface worked out... and look at that stain on that PVC. Now I just have to calculate all the port lengths and stain them ;-)
Here's the setup installed (minus the ports)
2011 Chevrolet Aveo(click for build log)
Clarion NX-603
SKAR 4500.1D
Iraggi 320A alt
Knukonceptz 1/0 Kollosus Fleks Cable
8 AWG Sky High Car Audio OFC
1/0- Sky High Car Audio
2- XP3000 XS Power Batteries
SMD VM-1
2- 12" Ascendant Audio Mayhems
Toolmaker Fuse block
Toolmaker Bus Bars
(Last Season scores 1-15" Mayhem)
145.2 dB- Sealed @ NSPL World Finals (9/28/14)
148.1 dB- Hardcore @ NSPL World Finals (9/27/14)
150.23-- Hardcore on 4500 Watts!!!!
New Build (2015, 2-12" Mayhems)
146.9- Sealed on dash
149.6 dB- Hardcore in Kick (No wall 0-24" Hardcore)
Started this season off right. The 2 12's are right where I left off with the 15. I had a massive air leak with my ports, and no time to tune before the show, but the numbers were ok.
I got a 145.5 dB and 145.7 dB (both sealed on the dash), and a 148.1 dB (hardcore, mic in kick).
Took home 2-2nd place finishes and a 1st place finish.
Got a few new things on order, and now it's time to tweak this thing ;-)
11144086_840096599361212_757542003120011
Clarion NX-603
SKAR 4500.1D
Iraggi 320A alt
SMD VM-1
Toolmaker Bus Bars
such a difference in the hatchback like yours vs. the sedan like mine...love the ride!
2007 Chevy Aveo Ls sedan
2 Sundown Xv2 on scv4k @ .5 ohm
2 pair RE XXX 6.5 components on sax200.4 @ 2 ohm
Big Three, Three runs 1/0 power from front to back, 1 ground front to back
Two runs ground from rear bank to chassis
XS power d3100 upfront, 3 Odyssey 2150s in bank
Singer 220 amp alt
Thanx Hoit,
I have grown fond of the hatchback setup.
Oh yeah... got some goodies on the way... here's one ;-)
11171431_844152618955610_1649924864_o_zp
Clarion NX-603
SKAR 4500.1D
Iraggi 320A alt
SMD VM-1
Toolmaker Bus Bars
Well guys, I enjoyed this weekend. Went up to VA and hung out at the TDH show.
I got my SMD VM-1 installed.
Got my new Sky High fuse blocks and ran my second run of 1/0.
I finally tuned the amp properly. Having the second run of 1/0 definitely helped keeping up my voltage. I'm happy with the results. 149.58 dB (sealed, forgot to move mic, mic in kick).
Hardcore- 149.97 dB.... So close....
I enjoyed TDH, over 880 cars and 130+ competitors (IIRC). I also took home a few second places.
Clarion NX-603
SKAR 4500.1D
Iraggi 320A alt
SMD VM-1
Toolmaker Bus Bars
Had fun competing yesterday... took home a few more medals, even though the weather didn't help anyone's score...
22315_852048751499330_759402094332526807
Clarion NX-603
SKAR 4500.1D
Iraggi 320A alt
SMD VM-1
Toolmaker Bus Bars
  • 3 months later...
So... this happened... and here are the pics...
New Stickers (had to add DBz, right)
I rebuilt the enclosure probably a month ago or so... This was how everything looked in the car before the rebuild...
My wife drives the car one day.... and says the back seats need to go!!!!
So, while I had the car tore down for troubleshooting (turned out to be a bad battery), I did this...
I cut a steel frame to lay out everything... #WhoAintGotNoWelds...
Finally going to have a spare tire again... (just means that I need more batteries)
Cut out and rounded over the holes for the fans...
Moved the batts over behind the driver's seat... so I could mount the fuse block upright
She's gettin' closer...
And here's the money shots!!! (don't mind the ports... I still have to test and cut/stain new ones)
Clarion NX-603
SKAR 4500.1D
Iraggi 320A alt
SMD VM-1
Toolmaker Bus Bars
  • 4 months later...
6k, 2-15"s and 150.8 dB without any tuning....
Oops, wrong chat....
Clarion NX-603
SKAR 4500.1D
Iraggi 320A alt
SMD VM-1
Toolmaker Bus Bars
  • 6 months later...
Guess I should update this build. It's been awhile. Well, I've been busy plugging away at work and school, so this season has kinda sucked...
I'm currently running my 2- 12" Mayhems, on a Rockford T1000-BDCP, while I wait on my 4 CAB-1600's to come in. I really need to start a build log for my truck too, since the wife will have a system in there soon...
One of my latest projects was to put a temperature sensor in the amp to let me know before things get too hot. I had been running a surface mount sensor on the chassis of the amp for awhile now, but I wanted this one inside to tell me the temperature that the mosFETs (well, technically the heatsinks/clamps for the FETs) are seeing. This should be able to give me an early warning if something has gone wrong.
Here's a nice pic of the amp guts... (sorry, photobucket wasn't letting me rotate the pic).
Then we take a simple little temp probe, like pictured below.
received_1040913859279484_zpsc2hbkfxm.jp
Attach it to the mosFET clamp like so...
Drill out the faceplate, and route the wire through.
received_1040920685945468_zps3rdsu2wh.jp
Slap the top cover back on the amp, and we have ourselves a nice little package.
received_1040922629278607_zpsvdgrvoo2.jp
Route the cable through the car, then crimp these little boogers on and terminate the cable.
received_1040924595945077_zpsgwrq73kc.jp
And success... The meter shows me the temp...
Keep in mind this is merely a working prototype. I have identified some things that I would like to change and some improvements before I ever would attempt to sell these to anyone.
Clarion NX-603
SKAR 4500.1D
Iraggi 320A alt
SMD VM-1
Toolmaker Bus Bars
