purplehaiz Posted August 23, 2012 Report Posted August 23, 2012 I just got my new alt installed. Right after I idled at 12.6 but I could hammer it as long as I wanted to without my amp cutting out. Now after I put my new fuse on I idle at 13.8 but my amp cuts out the second i start turning gain up. And my terminals on the front main battery are very very easy to move. They are those cheap ones with about 4 inputs for wires and are tightened by set screws. But the screws won't tighten. I'm assuming the cutting out is due to those termianls. Am I correct.
TheBetterMethod Posted August 23, 2012 Report Posted August 23, 2012 Yeah probably 2005 Subaru Outback Wagon Pioneer 9400BH Fi Q 15, SAZ1500dV3 The first build>>> http://www.stevemead...-outback-build/ 140.9 @ 36hz Sealed on dash! REBUILT!!! 2 Fi Q 15s, 2 SAZ1500dv3 146.9 @ 39hz dBDRA certified
audiofanaticz Posted August 23, 2012 Report Posted August 23, 2012 yes. if they are loose and able to move freely even when tightened as much as possible your ending up trying to force more current threw less metal. IE the terminals are loose, the connection is poor, so now instead of the current flowing thru a solid tight connection where the surface area is much greater, its forced to go threw smaller amounts of metal with less contact because they are loose. If you cant get them tightened all the way, you have the potential to get the terminals and or power wire hot, which could melt the rubber as well as start a fire.... I wouldnt really use your stereo until you fix the needed issues to make the terminals fit tight as possible
Skullz Posted August 23, 2012 Report Posted August 23, 2012 Get some lugs for the wire and use these and you'll never have to worry about loose wires ever again. http://www.amazon.com/dp/B001QRTZR0/ref=pe_175190_21431760_M2C_ST1_3p_dp_1 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2
Mtnbikecrazy55 Posted August 23, 2012 Report Posted August 23, 2012 Get some lugs for the wire and use these and you'll never have to worry about loose wires ever again. http://www.amazon.co...M2C_ST1_3p_dp_1 damn, them some hardcore terminals! I hate long signatures.... ...what the fuck is wrong wiht you you fucking fuckity fuck fuck head... Mtnbikecrazy55 Feedback
purplehaiz Posted August 24, 2012 Author Report Posted August 24, 2012 I should be getting them tomorrow. I now idle anywhere from 13.5 to 14.0. With my system all the way up i do not drop below 12.1. No cutting out of the amp or anything.
purplehaiz Posted August 24, 2012 Author Report Posted August 24, 2012 Installed new terminals and fuse block. Idle at 14.4 right away. That will climb. With it all the way up it doesn't go below 12.6. That's at idle. No cutting out. Running a mechman rhino 250.
