I'm ready to try a new enclosure design out for my 2 12" SSA Xcon's. They are currently in 7 cubes @ 33hz and I'm wanting to cut back on size a lot.
I want another ported box anywhere around 28-32hz and subs firing up along with port as well (if possible). I've messed around with re box calculator and have come up with subs up and port forward.
Amp is a 3000d and vehicle is a 01 F150 extended cab with no back seat and I listen to all genre's.
Max external dimensions I have are 30" wide x 30" tall x 16" depth
Any help or ideas are appreciated!
Thanks!
(2) 12" Xcon's/ 18" btl/saz3000d /pioneer deh-p5100ub/RF T1652-s/sax 125.2
So you want to go from 7net to within 7gross with a lower tune
Can't work out the tune but idd want to aim for 5net @28hz with 75-80sq" of port
No, I want around 5 like you're saying, I was just giving my MAX dimensions. I don't want to exceed those at any means.
maximize the screen and alt + print screen
then open up paint and paste it
then save it as a jpeg
or just type in the actual specs/dimensions on here if you don't mind
So here is a suggestion:
Enclosure Specifications:
Fb = 32 Hz
Vb = 4.5 ft^3
External Height = 30 in
External Width = 30 in
External Depth = 16 in
Port Width = 5 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
2 x Top & Bottom (3 parts) = 30 x 16
Left & Right Sides = 14 1/2 x 27 3/4
Front & Back = 30 x 27 3/4
L Port Internal Assembly Parts:
Top to Bottom = 22 3/4 x 14 1/2
Extension = 3 x 14 1/2
Assembly guide (generic dimensions):
Crossbraces are 1.5" diameter, let me know any questions.
That's awesome Joe X
My only concern is......2 12" subs that are 12.5" each overall diameter = 25" + a 5" port width....means the subs would be right next to one another on top of the port.
  • Who's Online   0 Members, 0 Anonymous, 1746 Guests (See full list)
