Using only 1 voice coil?
Tim Lam
willdkartunes
Standard Member
United States
Posts: 270 Posted: March 18, 2006 at 12:22 AM - IP Logged link_to_post.gif post_reply.gif quote_icon.gif bmwpwner wrote:
from my understanding that is the whole point of having a DVC. you can go either 4, 8, or 2 ohm loads depending on the wiring. what is the downfall of using only one voice coil?
You are completely correct! That is exactly the point of having a DVC subwoofer. Different wiring options! The only downfall to wiring only one voice coil is you have to run lower wattage to the subwoofer. Of course, there is an upside too. (already stated earlier by haemphyst)
I knew guys that use to do this all the time when I was younger. (hook up only one voice coil of a DVC sub) They loved this new idea of subwoofers having dual voice coils. Don't know how it first started, but a very cool invention. So is the removable voice coil.... very sweet. Much cheaper too!
___________________________________
Do whatever makes you happy in life without diminishing the happiness of others
I believe hhr Ed posted a video about box rise and in it he mentioned you can run 1 coil off a DVc sub. IIRC he said it just couldn't handle as much power with 1 coil hooked up.
Pioneer deh-8300UB
6- Image Dynamics CSX6.5v2
4-Image Dynamics XS-28 tweeters
4-Sundown Audio sa8v2's
1-Sundown Audio SAX-200.4
1-Sundown Audio SAX-1200d
1-Mechman 270a alternator
1-XS Power D3400 under hood
Second Skin Damplifier Pro Deadener
Kicker & Knukoncept 1/0 wiring
Big 3 upgrade
You can use one coil, just cuts the power handling.
Current system:
1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s
Previous systems:
2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz.
1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
1/2 the power handling.
Simple really
thats the vid
What the f**k is an appropriate signature supposed to look like?
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
Rockford Prime 200.2
Pioneer 6.75" Comp Set
XS S3400, D2700
Project DB Battery Terminals
Axxess ASWC
Stinger HPM Everywhereeee
90 Sq. Ft. of Stinger Roadkill
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/
My Old Build: http://www.stevemead..._+2000 +mustang
Avatar Courtesy of SnowDrifter
I think you may run into problems when you start to reach the power handling limits of the voice coil. What I mean is, say you have a dvc at 300rms per coil. You put 300rms into said coil, but the other see's no power. Now the suspension of the sub is designed to work with a certain motor force behind it. You are giving it half the motor force. But you are still throwing power at near the thermal limits of the voice coil. I think in that situation you may cause heat and distortion issues.
I am probably completely wrong.
Simple really
Exactly Ray. Dear god people like to complicate things.......
2011 Ford Ranger Sport 4.0 v6
2 sundown audio prototype nsv4 15s
crossfire 4k wired to 0.4 ohm
15 banks of maxwell 3.0 caps @ 18v
triple alts (x2 us alt 250's, x1 singer 320)
153 at 23hz
You are. . .
Sorry, I am in a smart A$$ mood tonight. . .
Current system:
Previous systems:
no need to apologize, lol. I just had some dvc many years ago and with one coil unhooked it distorted sooner than with two. But there are too many factors to ever figure why that happened.Probably just cheap subs and or amps.
  • Who's Online   0 Members, 0 Anonymous, 2422 Guests (See full list)
