bighoss' 2006 f150, truck is gutted
Still cant get anything done with all this rain so I got bored and took a comparison pic of one of my tweeters and a xfl and a pic of the hdc3 10" going in my wife's Veloster compared to a xfl 12"
These tweeters are ridiculous, 500w rms, 3" coil, 112db sensitivity and they weigh 15lbs each
Used to have a loud truck
I can't get over the size off those tweeters lol. Excited to see how this build turns out.
1997 Dodge Ram 1500 Ext. Cab Build
(2) Rockford Fosgate T0D412s
3.7 cubic foot ported box
(1) Rockford Fosgate T2652-S
(1) Rockford Fosgate T152
Pioneer AppRadio SPH-DA02
Clarion EQS746 Equalizer
Hifonics HFi1500D
Hifonics ZXi80.4
Custom Dash Bezel to hold Double DIN
Custom amp rack w/ cooling fans
Second Skin throughout entire truck
Optima red top battery
AudioTechnix wiring
Fuck, it turns out I cant fit all 9 subs on the baffle, the design right now is the absolute biggest I can fit while still being able to keep it a rectangle. New plan is 8 xfl's on 4 bc3500's at 1 ohm each with none of the subs inverted instead of 9 subs on 3 3500's at .67 ea with the bottom 3 subs inverted. They will be on 2 3500's for now at .5 each until I can afford the other 2 amps. Im going to probably run 5-6 front baffles instead of 4 to take up some space in the wall. 6 baffles would put me at 17.76 cubes tuned to 34.7hz and 5 baffles would put me at 18.38 tuned to 34.1hz.
Sub layout:
I ran out of wood today but got it all cut except for the 2 top pieces and 1 back piece. I should have quite a bit of pics up tomorrow.
The way I've been doing it cut one of the pieces the right size then cut the other peice 1/2" bigger then come back and hit it with a flush trim bit on my router
Trimmed up
One of the baffles cut
It sucks but it is what it is. There is less than 1" between the subs. I'm either going to keep it as a spair or sell it. Idk yet.
3/8" threaded rod to help hold the wall in the truck
wall mocked up
back of the wall in, you can see the 3/8" threaded rod thats helping hold the wall in the truck, the 3/4" rod is going to be the front to rear bracing
got the sides up
more angle iron going in, its bolted to the wood and I put a bead of PL on it too
New door speaker wire and sub wire, its 100' of skyhighcaraudio 12ga and 100' skyhigh ofc 8ga for the subs,
Ihave a c1100.4 amp and 8 nendo 6.5 mids on the way too
Wow looks like a sick build!
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
Keep that extra sub as a spare man, you'll never know when you're gonna need it and don't want to wait 2 weeks for a new one!
Build id coming along nicely, but...... DId you hook up and listen to those fatass tweeters yet??
My name is AdamThis is my Civic Build.7" Samsung Tab 2Kenwood KDC-X896Clarion EQS746Sundown X-15DC 3.5k @2ohmHatersGonnaHate's 02 Civic UBLELD Bypass for Honda Civic/Accord/FitDon's Jeep Grand Cherokee Rebuild
N8ball2013 - i think you'd stick your dick in a blender if it told you it was 40 wtih two kids your age. lol
srp365 - If posting were picking up bitches, I'd be going home single tonight
looks like tony montana sneezed in your car.
