bighoss' 2006 f150, truck is gutted
I could be mistaken on the dates. But i know its in december and i KNOW i will have the gas money and i SHOULD be able to replace the skar with a real amp by then. Rebuild should be done in a couple weeks. Just gotta literally swap wires and a couple screws for the bass amp. EZ.
Ill see you there man. I gotta check the dates. I swore it was 13-14 on Usaci website for 2013.
Are you competing? I think im gonna show up and sign up, Do a quick run for shits and giggles for vs the old box and old amp. And then demo all day long like i did at heatwave.
Maybe it will be cooler then so my voltage will stay super high. 14's all days full tilt boys. 1 extra battery!
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
nope demo's only, I would be in either sb4 or modified 4001+ and I would get crushed lol, IMO if I was to wire to .25 I might have a chance but I have to pull all the amps out of my truck to strap and I'd rather not have to pull them if I dont have too
Used to have a loud truck
yeah, i made a comment on that the other day on the status updates.
Build to please you/ demo? or build to competition Reqs.
When i get my FL2 ill be in the 1000+ trunk class and the 601-1800 stock class. Basically ill be in the same class as a VFL 500.1 or other bigass amps. But ohwell. The XFL's want more power, I want more power, and my electrical is laughing at the 2500 even at .5 ohms. The other day i was decafing it out for a 25 minute drive home and never seen 13.6. At idle i do drop to 12.9 though. So no demos at idle.
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
If I was going for a comp build I would be running 4 aa 500.1's instead of the nendo's, that would put me in modified 1001-2000 and be more power than I have right now. I cant demo at idle, if I keep the rpms around 2000 I still drop to mid 11's on music if I push it hard
I don't trust those AA 500.1s, I have seen so many of them go bad, local guy runs them, and had issues with all the "The fix" amps except the original 1 of 50.
2003 Kia Sorento
Team Subsonic Lows
Team Bassin' on a Budget
I almost bought 2 of the second run ones but didnt want to wait a few months for them to come in
"the fix" 500.1's are 500@4ohm rated? DAFUQ?
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
Only if you could fit a 9-10 cube box after displacment and have 6-7k to power them, I'm honestly liking these xfl's better than my old hdc3's
What about 8 cubes after displacements tuned to 34hz. As long as I can hit 28hz decent' I'm good. That should allow me to hit around 28-45 pretty decent. That's the range I play the most.
87 Caprice twin-turbo 6.0
2 DC 15 xl's
Sundown 3k
96 Volvo 850r
3 15's on 9k - no wall
154.3db legal
www.youtube.com/boostdoctor
www.facebook.com/boostdoctor
So when is the big power coming?
Hopefully ill be getting a 2nd alt next month if I can find a bracket
