Jordan Guess Posted September 6, 2012 Report Posted September 6, 2012 okay so im on break before i go back to work and was hoping to start defusing the issue that my wife presented to me. From what she explained, when she started to drive down the street today, the truck was making a lunging, or jumping motion (at all speeds), and seemed as if the vehicle wanted to shut off. it occured to me that this could be a problem with faulty wiring with my alternator? i just installed a AQ2200 and wired it only at 2 ohms, but my battery and alternator are stock and im sitting at 13.8 volts while playing full tilt. I am running zero gauge to the amp, but i have not yet installed a "big 3" yet. I was hoping that maybe somebody could confirm why her truck is lunging and wanting to shut off, and that i very well could be just using to small of wire, or bad grounding because i have not done the big 3 yet? your help is much appreciated, thanks.
Keith77 Posted September 6, 2012 Report Posted September 6, 2012 Check engine lgiht on ? Whay make and year of car? Thats cool. Im way too old to be upset by shit like that. Your name is winston. Your own parents hated you even before you were born. My penis is bigger than your penis I'm far from loud and my roof/headliner flaps around like Adam's ass on a windy day. I think it depends more on the structure of the vehicle.
Jordan Guess Posted September 6, 2012 Author Report Posted September 6, 2012 yes check engine light has been on for a while, spark plugs were just changed about 2 months ago. its a 1999 Ford ranger XLT
Skullz Posted September 6, 2012 Report Posted September 6, 2012 You got something else going on. Possible fuel issue, ignition or sensor going bad, you'll need to get the codes pulled and see if there are any to point you in the direction of the cause. 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2
Guest Posted September 6, 2012 Report Posted September 6, 2012 check what the engine light code is for. autozone does it for free. edit: i dont see how installing an amp (especially when not playing music) will cause a car to lurch and jump.
Jordan Guess Posted September 6, 2012 Author Report Posted September 6, 2012 would a bad O2 sensor be a cause of it?
fox_racin4 Posted September 6, 2012 Report Posted September 6, 2012 No Its hard to diagnose an issue without acctually being in the drivers seat, Did she have the system playing? If ots putting a big load onto alt, it will surge a bit Again.. Hard to say without being in drivers seat 1998 gmc extd cab 12 crossfire C710s 4 SAZ-4500s 3 Singer 400A altsbuncha mids/highs Team Asshole
Jordan Guess Posted September 6, 2012 Author Report Posted September 6, 2012 i dont think she had the system playing. i am going to do the big 3, and change the o2 sensor, (she just got the check engine light code-was the o2 sensor). and see how it goes from there.
Skullz Posted September 6, 2012 Report Posted September 6, 2012 I have seen water in the fuel cause the same thing your describing but do not buy anything unless you know you need it and get the codes pulled so you replace the parts needed and keep from buying ones that don't need to be replaced. 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2
