Need some opinions and advice
What kind of amp are you running that claims to need a 250amp fuse but only has 4ga inputs ?
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
One thing that needs to be clear, you fuse for your current draw, NOT the wire. What amp are you using?
I'm thinking the same thing! My T1000 requires 150A and has 4 gauge inputs. I would think a TRUE 250A requirement would be an amp that truly gave 2500W. For 2500W 4 gauge is way too little to support the current.
I'm just curious on this comment. You just fuse for whatever the amperage requirements of the amp? So if it tries to pull 250A through 4 gauge wire, couldn't that just straight melt the jacket? Or is the idea that the fuse would blow before that happens, hence the reason for the fuse in the first place?
I think the idea is that the fuse would blow before that
  • Who's Online   0 Members, 0 Anonymous, 1249 Guests (See full list)
