252chevyboyz Posted September 20, 2012 Report Posted September 20, 2012 Yes sir something like photobucket works great. Hope we can get some pics of the problem area. I got a pic of my HDC3 18 spider landing if you want me to upload that. Just let me know. Hope this helps - 1997 Chevy Tahoe- Big 3 (1/0)- Dual Autocraft Batts- JVC KD-A315 HU- AQ 2200.1D- 18" AQ HDC3- Box w/ Removable Port (6ft^3 @ 36hz & 6.7ft^3 @ 42hz)- 39' 1/0 & 13' 2/0 Flex-A-Prene My Selling Feedback Build Log
Bump4life Posted September 20, 2012 Report Posted September 20, 2012 its not hard to recone a sub at all man. order those AQ recone kits. they give you everything to do it. shims to center coil and all. youtube videos teach you all. learn the rest from experience. at least the recones are cheap so if you mess up its not too expensive. Buyer/Seller Feedback Thread: http://www.stevemead...5015-bump4life/ MB C220 153 Trunk Car Build Log: http://www.stevemead...d/#entry1840136 MB C280 Ipad Dash SQ Build Log: http://www.stevemeadedesigns.com/board/topic/194484-bump4lifes-new-benz-tony-c-relay-kit-pictures-ce-electric-audison-front-stage-installed/ My SPL Log: http://www.stevemead...__fromsearch__1 BMW M340 xDrive Stock, for now. Corner Load 10" maybe soon. But does 10s in the 1/4... Best Scores out of a trunk 153.0 sealed legal full tilt clamped 5524 @ 42 hz 154+ windows down, 155+ kick
TheInfamousImpala Posted September 20, 2012 Author Report Posted September 20, 2012 Yes sir something like photobucket works great. Hope we can get some pics of the problem area. I got a pic of my HDC3 18 spider landing if you want me to upload that. Just let me know. Hope this helps Could You Please? and like i cant the part close to the motor Detached (The Bottom of the Cone) 2003 Impala LS "Under Reconstruction"
TheInfamousImpala Posted September 20, 2012 Author Report Posted September 20, 2012 its not hard to recone a sub at all man. order those AQ recone kits. they give you everything to do it. shims to center coil and all. youtube videos teach you all. learn the rest from experience. at least the recones are cheap so if you mess up its not too expensive. Yea I think imma go ahead and recone myself i just have to get them taken apart first 2003 Impala LS "Under Reconstruction"
bigtizzony Posted September 20, 2012 Report Posted September 20, 2012 Can anyone point me in the right direction to get a recone kit for mmats p3 15
252chevyboyz Posted September 20, 2012 Report Posted September 20, 2012 Here is the pic of the spider area. Also this is my ongoing process of reconing a SA-8 v1.5 and you might be able to pull some ideas of how to disassemble by looking at this. http://www.stevemeadedesigns.com/board/topic/150982-reconing-sa-8-v15-w-pics-pg-3/ Also a thread I like to look at for reconing http://www.stevemeadedesigns.com/board/topic/33737-how-to-recone-a-sub/ To get the spider out and the coil out you can take a razor and cut the spider all the way around and then proceed to to pull the spider and coil out. I do believe around the spider there is a ring that helps clamp the spider to the landing. Just remove the bolts/screws from that ring and then just pull the ring off and the spider should come on out. Please correct me if I'm wrong - 1997 Chevy Tahoe- Big 3 (1/0)- Dual Autocraft Batts- JVC KD-A315 HU- AQ 2200.1D- 18" AQ HDC3- Box w/ Removable Port (6ft^3 @ 36hz & 6.7ft^3 @ 42hz)- 39' 1/0 & 13' 2/0 Flex-A-Prene My Selling Feedback Build Log
Crandis16 Posted September 20, 2012 Report Posted September 20, 2012 contact this guy... does great recones http://www.facebook.com/splaudio.dean My Red zx2 Build Log My Black zx2 Build Log My Red zx2 UBL
bighossf150 Posted September 20, 2012 Report Posted September 20, 2012 mine were $460 shipped from psi to get both of my 18"s rebuilt by them but thats with a ton of options, direct leads, colored cone, carbon fiber dust cap and a 2500rms rating on each Used to have a loud truck 2009 Corvette Z06, H/C/I, 150 shot, g force tune, 730rwhp/690rwtq 2013 F-150 limited, MPT Tune, leveled on 35"s
wmrcs Posted September 20, 2012 Report Posted September 20, 2012 Here is the pic of the spider area. Also this is my ongoing process of reconing a SA-8 v1.5 and you might be able to pull some ideas of how to disassemble by looking at this. http://www.stevemead...15-w-pics-pg-3/ Also a thread I like to look at for reconing http://www.stevemead...o-recone-a-sub/ To get the spider out and the coil out you can take a razor and cut the spider all the way around and then proceed to to pull the spider and coil out. I do believe around the spider there is a ring that helps clamp the spider to the landing. Just remove the bolts/screws from that ring and then just pull the ring off and the spider should come on out. Please correct me if I'm wrong Yep, just unscrew that spider ring and cut the whole spider, coil cone etc out. The just get every bit of spider and surround off of the surface of the basket as best as you can. I used an angle grinder. Then clean the surface with rubbing alcohol and your good to start gluing down the new spider/surround. It's really simple. Oh and btw, getting that spider ring back in is a PITA, so just ditch it. E34 540iT/6
TheInfamousImpala Posted September 20, 2012 Author Report Posted September 20, 2012 Here is the pic of the spider area. Also this is my ongoing process of reconing a SA-8 v1.5 and you might be able to pull some ideas of how to disassemble by looking at this. http://www.stevemead...15-w-pics-pg-3/ Also a thread I like to look at for reconing http://www.stevemead...o-recone-a-sub/ To get the spider out and the coil out you can take a razor and cut the spider all the way around and then proceed to to pull the spider and coil out. I do believe around the spider there is a ring that helps clamp the spider to the landing. Just remove the bolts/screws from that ring and then just pull the ring off and the spider should come on out. Please correct me if I'm wrong Yep, just unscrew that spider ring and cut the whole spider, coil cone etc out. The just get every bit of spider and surround off of the surface of the basket as best as you can. I used an angle grinder. Then clean the surface with rubbing alcohol and your good to start gluing down the new spider/surround. It's really simple. Oh and btw, getting that spider ring back in is a PITA, so just ditch it. Will Do Thanks Man And what did you unscrew it with? 2003 Impala LS "Under Reconstruction"
